Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 74
  1. #21
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    Kubota B3200, Ford NAA, IH 454D, Case 1845C
    Default Re: Me A Happy Camper - 1975 Dodge 500
    Quote Originally Posted by crash325 View Post
    After 2 Hours & 1 Beer. 1/2 The time looking for tools, 2 1/2" Socket, Square socket for lugs on inside tire, etc.
    Looks good, but you did it the hard way IMO
    I just replaced the rear wheel cylinders on my '75 C-60 Chevy. Pulled the axle shaft, removed the hub nut and lock, put the forks under the duals and slid the whole thing off as a unit with the tractor. No heavy lifting, had it down to the brakes in about 10min.
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    Case 1845C skid steer
    JD 265
  2. #22
    Super Member crash325's Avatar
    Join Date
    Feb 2011
    Posts
    9,169
    Tucson AZ
    New Holland TC-45
    Quote Originally Posted by Verticaltrx View Post
    A few years ago I did the other side that way. But would had to spend 3 / 4 hours moving stuff around, it would have also doubled the tool chasing distance.
    Since I am real good at forgetting the right tool or just plain getting the wrong 1, took that into consideration.
    Maybe next year I will play Chevy, need to put an engine & clutch in my 1974 C65 Dump truck.
    Tomorrow off comes the master cylinder, like to find a rebuilt or a repair kit, but will take what I can get.
    ::"I STARTED out with nothing....I still have most of it."
    New Holland TC45 1,300+ hours - FEL - back hoe - post hole digger - Hydraulic Gannon - cement mixer - pressure washer - 1975 Dodge 500 flat bed - 1974 chevy C65 6 yard dump truck.
    All home made by me. loading forks - 2 drags - roller - Sheep's Foot - Pusher (to unload flat bed truck.) - pickle fork digger - Log splitter -
  3. #23
    Gold Member NormL's Avatar
    Join Date
    May 2011
    Posts
    475
    Manitoba, Canada
    Craftsman GT18, Ford 601 / FEL, Oliver 550 / FEL
    Years ago I had a small fleet of similar trucks - mine were the 600's. When I did brakes and/or seals, I jacked up the duals, slid a greased sheet of cheap plywood under them and let the wheels down till just the weight of the duals was resting on the plywood. Then out came the axle and everything holding the wheels and drum, then slid the works out. Reassembly was everything in reverse, being careful to have the axle tube and drum seal lined up perfectly. I had a bum back then as now and could not lift those wheels. This way I didn't have to.
    I miss Paul Harvey News!
  4. #24
    Join Date
    Feb 2011
    Posts
    9,169
    Tucson AZ
    New Holland TC-45
    Bad day at Black rock.
    Early AM call parts store, master cylinder for a dodge D500 truck. We Got one only $100, I'll put it on the shelf with your name on it. 60 Miles 1 way and what he had was not even close, maybe fit a car. 1 Hour + many places checked, "Midland 300407" Midland has it $400 for a rebuilt, $500 for a new one. That is with a discount. Disgusted, don't even pick up the few little groceries that I need.
    Stop for a beer & burger, not been there in about 4 years, good burger, fires OK. 2 12Oz draft beers, with tip $15. If I remember last time in ti was that much for 2 people.
    Start typing this, power goes off, only for a minute or 2, just enough to crash the computer.
    Later today or tomorrow, search the net for a reasonable price for a master cylinder. Maybe just get a whole master cylinder & vacuum out of some other vehicle & make it work.
    Not going to pay $400 for a few seals & cups.
  5. #25
    Join Date
    May 2011
    Posts
    475
    Manitoba, Canada
    Any chance you can rebuild the one you have yourself? Or are the cylinder walls pitted too deeply to salvage?
  6. #26
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    If you can measure the bore of the master cylinder I bet you can find a rebuild kit that will work, maybe even if its for a different application. So far the parts availability for the old Chevy's is pretty good, Carquest and NAPA carry a lot of heavy truck parts. Is your C65 a single axle or a tandem?
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    JD 265
  7. #27
    Join Date
    Feb 2011
    Posts
    9,169
    Tucson AZ
    New Holland TC-45
    Quote Originally Posted by NormL View Post
    That is sort of the plan, but have not been able to locate the right seal or cups. Have rebuilt quite a few (not this odd ball 1) over the years.
    Tomorrow the internet will get a work out with me looking.
    Had almost enough fun for 1 day, 1 more beer & its bedie By.
    Thanks
    Jim
  8. #28
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,893
    Northern Vermont
    Kubota, Case, Deere
    My hat's off to you. I have an old IHC 1700 4x4 fire truck (hose) that I've always wanted to turn into a flat bed. It's only got about 25k on her but it's been years and I still have found the time.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  9. #29
    Join Date
    Feb 2011
    Posts
    9,169
    Tucson AZ
    New Holland TC-45
    Men, women, boys & girls, I sure could use some suggestions on where & what to look for.
    Have gone to well over 100 web sites or pages. Can't find anything even close to the right master cylinder.
    Looked under Dodge D500 truck, M500 motor home (same chassis), even looked at the 300 series.
    Checked out several auto parts & truck parts stores, looked under Midland brakes, Wagner brakes, Bendix brakes.
    Vintage & antique Dodge parts
    2 Problems, MC is an oddball, (Picture tomorrow) brake lines attach on passenger side of cylinder. Front brake line is 5/16" & rear 1/4".
    Running out of ideas.
  10. #30
    Join Date
    Feb 2011
    Posts
    9,169
    Tucson AZ
    New Holland TC-45
    2 Days of internet searching. Actually found a replacement cylinder, a rebuilt direct from Halex / Midland. "Only" $313 + $120 Core charge (refundable).
    Still a ridicules price for less than an hours labor & a few seals.
    Think I will adapt a Bendix 12008 brand new cylinder $47.99
    See pictures & please tell me what you think.
    Me A Happy Camper - 1975 Dodge 500-mc-1-jpg -Me A Happy Camper - 1975 Dodge 500-mc-2-jpg -Me A Happy Camper - 1975 Dodge 500-mc-3-jpg -Me A Happy Camper - 1975 Dodge 500-mc-4-jpg -Me A Happy Camper - 1975 Dodge 500-mc-bendix-jpg
Similar Threads
  1. Happy Camper (Farmer)
    By drjay9051 in forum Attachments
    Last Post: 09-09-2010, 01:15 PM
  2. Happy Camper
    By mjarrels in forum Rural Living
    Last Post: 04-13-2008, 10:21 PM
  3. One Happy Camper
    By workhorse in forum ATVs & Utility Vehicles
    Last Post: 02-01-2008, 01:08 AM
  4. Ordered my XUV today!!!!! I'm a happy camper now.
    By gordon21 in forum ATVs & Utility Vehicles
    Last Post: 03-07-2007, 08:07 PM
  5. I'm a happy Camper !!
    By NIXON in forum Kubota Buying/Pricing
    Last Post: 10-27-2003, 10:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
