Page 5 of 8 FirstFirst ... 2345678 LastLast
Results 41 to 50 of 74
  1. #41
    Super Member crash325's Avatar
    Join Date
    Feb 2011
    Posts
    9,149
    Tucson AZ
    New Holland TC-45
    Default Re: Me A Happy Camper - 1975 Dodge 500
    Actually another day of progress. Not an easy day.
    200+# drum had to be taken off after the first try. Try & Try, it would not go all the way on. Even used a ratchet strap trying to get on all the way.
    Remove drum, new seal is slightly cocked. Just talking about 1,000ths of an inch. Tap it out, check fit on axle shaft, very tight but will go on. Make sure the bearing will slide on, near perfect alignment required. Seal could have been made about 8 to 19 thousands smaller. Hardest I ever had to hammer a seal in.
    Second try and it goes on, part way. Seal & bearing are started, but it stops about 1 inch from going all the way. Heavy hammer & block of wood between axle studs and it does go all the way.
    Using my home made tool the gland nuts went on. Back nut a little difficult as the first guy in this well had buggered the threads a little.
    Tighten up bearings until drum will not turn, back off 1 flat (1/8 turn). As some nice person reminded me a few posts back.
    Pictures show the drum on and the simple tool that I made. You can't keep a determined redneck down.
    Me A Happy Camper - 1975 Dodge 500-tool-n-drum-jpgMe A Happy Camper - 1975 Dodge 500-tool1-jpg
    ::"I STARTED out with nothing....I still have most of it."
    New Holland TC45 1,300+ hours - FEL - back hoe - post hole digger - Hydraulic Gannon - cement mixer - pressure washer - 1975 Dodge 500 flat bed - 1974 chevy C65 6 yard dump truck.
    All home made by me. loading forks - 2 drags - roller - Sheep's Foot - Pusher (to unload flat bed truck.) - pickle fork digger - Log splitter -
  2. #42
    Join Date
    Feb 2011
    Posts
    9,149
    Tucson AZ
    New Holland TC-45
    Moving ahead, however slowly.
    Inside dual is on and brakes adjusted. After adjusting both adjusters the wrong way, it only took twice as long as it should have.
    Getting the tire on worked out to be fairly easy. When the jack was let down on the stand the hub was a little lower than center. Leaned rim over hub and jacked it up until the rim slid over the hub. 3/4" Impact socket fit over lug bolts and inside the holes in the rim. A little prying & hard push got 1 lug through the wheel & lug nut started. From there it got even easier, just push & start nut. Run them down with the impact.
    I left the axle out so that turning the wheel to adjust brakes would be easier.
    Question!! Have any of you used a Vacuum brake bleeder??? It will be my first time using one. Use to have a pressure bleeder or had a helper to work the brake pedal. Any hints or tips would be appreciated.
    Me A Happy Camper - 1975 Dodge 500-tire-2-jpgMe A Happy Camper - 1975 Dodge 500-tire-jpg
    Then it was lunch time. 2 Brats for me & 1 for the dogs.
    Me A Happy Camper - 1975 Dodge 500-lunch-time-jpg
  3. #43
    Join Date
    Apr 2000
    Posts
    1,762
    North Central Arkansas
    John Deere 4520,
    Quote Originally Posted by crash325 View Post
    Jim Looks like some one able to train the dog to get you back home after a all nighter. It would be no problem to get the dog to step on the brake and hold .
    Also let him drive the truck for the first trial run.
    Going to Mt. View for a trip with our camper to check if all is good. Also a country music show .
    Keep posting the truck repair problems. Does the engine run?
    ken
  4. #44
    Join Date
    Feb 2011
    Posts
    9,149
    Tucson AZ
    New Holland TC-45
    Quote Originally Posted by Ken View Post
    ken
    Good to hear from you Ken.
    I'm have a little trouble with my dog training program. Youngest one (Brat - her name & she lives up to it.) wants to drive. Seat over 4' up and she jumps in flat footed. Then sits there with a when are we going for a ride look.
    Reason for the happy camper name to the thread. After sitting for over 2 years it did start & run. Second day as I was about to give up, it fired off.
  5. #45
    Join Date
    Nov 2008
    Posts
    172
    East TN
    '10 Kubota MX4700HST, R4s
    I've used a mini-Vac several times. It's the cat's meow if you're working alone. You should have no problems bleeding with the mini-Vac.
    mkane09
  6. #46
    Super Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    6,943
    Willis, Texas
    Mahindra 6520 4WD
    Jim,
    I had a Snap On Tools hand vacuum pump years ago. I quit working on small airplanes and let it set for years and years. Tried to use it a year or two ago and the seals were dried out. It wouldn't work. But it is the cat's meow when new and working by yourself. If you pour what you vacuum out back into the master cylinder, be sure to filter it with pantihose.
    You can also use an old fashioned pump up oil can to pressure up the lines and bleed them. We usually tied the tubing to the bleeder valve with some saftey wire. Just don't pump the little oil can dry. Which is tedious in itself. This worked on a small airplane, so I guess it would work on automotive brakes.
    hugs, Brandi
  7. #47
    Join Date
    Mar 2002
    Posts
    221
    East Texas
    I recently used a vacume bleeder for the first time while rebuilding the brakes on a boat trailer with surge brakes. might be the only way I bleed brakes from now on.
  8. #48
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,446
    Texas
    The last brake job I did was in January, 2007; front brakes on my brother's F350 Ford and one caliper had to be replaced. We didn't have a vacuum actually made for the purpose, but my air powered siphon spray gun did the job just fine.
    Bird
  9. #49
    Join Date
    Apr 2000
    Posts
    1,762
    John Deere 4520,
    Jim following your posting of problems on the "camper'
    Need a vacuum run a piece of tubing from the vac. advance on your engine. clear tubing can see the brake fluid in tubing. Same type used to run water to refrig. works.
    I have never purchased a pick-up or car that didn't need the wheel cyl. or brake fluid replaced.
    ken
  10. #50
    Join Date
    Feb 2011
    Posts
    9,149
    Tucson AZ
    New Holland TC-45
    Thanks Brandi & guys,
    Your advice is much appreciated. This vacuum bleeding is a new thing to me. Got an El Cheapo from HF to try it out.
    I do plan to flush the whole brake system with new fluid once everything is working & sorted out.
    I have managed to stretch a 3 to 5 hour job into weeks & days. Good thing I,m not working for wages, good chance I'd get fired.
Similar Threads
  1. Happy Camper (Farmer)
    By drjay9051 in forum Attachments
    Last Post: 09-09-2010, 01:15 PM
  2. Happy Camper
    By mjarrels in forum Rural Living
    Last Post: 04-13-2008, 10:21 PM
  3. One Happy Camper
    By workhorse in forum ATVs & Utility Vehicles
    Last Post: 02-01-2008, 01:08 AM
  4. Ordered my XUV today!!!!! I'm a happy camper now.
    By gordon21 in forum ATVs & Utility Vehicles
    Last Post: 03-07-2007, 08:07 PM
  5. I'm a happy Camper !!
    By NIXON in forum Kubota Buying/Pricing
    Last Post: 10-27-2003, 10:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
