Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Member jmusser15's Avatar
    Join Date
    Mar 2010
    Posts
    47
    Fulton County, PA
    Kioti RX6010
    Default New Pole Building
    Well finally the day has arrived. I have been saving for 2 years for this day. They began construction today on my 32'x56'x16' eve height pole building. It will have a 14'x14 door for storage of my motorhome and two 10'x9' doors for the truck and tractor entrances. They are setting trusses tomarrow and starting the metal too, then supposed to be finishing on Friday. I will continue to post progress pics.
    New Pole Building-image-2634793535-jpg
  2. #2
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Default Re: New Pole Building
    Congratulations! Has to be a good feeling to see your goals coming true.
  3. #3
    Super Member deerseeker001's Avatar
    Join Date
    Jul 2011
    Posts
    7,878
    Central wisconsin
    International 2500a with Loader
    i am happy for you i remember going through that i know the feeling
    ::welcome :::RON
    never stop learning.
  4. #4
    Platinum Member DutchHenryBrown's Avatar
    Join Date
    Aug 2009
    Posts
    907
    Tombstone, AT
    Mahindra 5010
    Looks very nice, your lucky you have a good crew and they know what they are doing.
  5. #5
    Gold Member idaho2's Avatar
    Join Date
    Aug 2009
    Posts
    415
    SW WA / North Idaho
    Mahindra 5530 4WD Turbo - Gear,
    jmusser15,
    Does your tractor have ROPS and will it clear the shop door when it is all the way up. Saw this happen and they have to drop the ROPS to clear the raised door!
    idaho2
  6. #6
    Platinum Member Dr Dave's Avatar
    Join Date
    Feb 2012
    Posts
    849
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    Congratulation on your new building! Were are you located? I think 10x10 doors would be minimal size, unless there is a clearance issue. You need to think about future use's also.
    10x9 is an odd size, 10x10 may be cheaper?
    Dave
  7. #7
    Silver Member samhudson3's Avatar
    Join Date
    Sep 2011
    Posts
    203
    Central NC, Southern part of Heaven
    John Deere 4300
    Nice! Congrats, it's good to see dreams coming true. I've got a barn on the family farm to restore (built 1914?) has great bones, but siding and tin need replacing. One day it will happen..
    Sam
    JD 4300 HST with FEL, bush hog, rear mower, tiller, row hipper, cultivator, post hole digger, blade, and a wish list of more.
  8. #8
    Join Date
    Jun 2011
    Posts
    65
    Browns Valley, MN, USA
    It is always exciting to see people get new buildings, which solve their problems.
    I am impressed your builder selected glu-laminated columns for your building, they are a superior product.
    Some things which amaze/surprise me:
    Why it is builders persist in placing posts every 8'? Considering steel roofing and siding comes in multiples of 3' neither 32' or 56' results in an even number of steel panels per wall. More work for the builders, and a small, but unneeded waste of material which the building owner ends up paying for.
    Also (with 8' column spacing), the wall girts as installed, do not meet with the requirements of the Building Codes: Them Girts, They Be a Bending
    Unless there is a tricky access to the large overhead door, paying the huge premium for a 14' wide door, rather than the more standard 12' wide is something I do not understand either. For the cost of 14', one might as well pay the few extra dollars and go with 16' wide, which at least would allow for two cars to enter side-by-side.
  9. #9
    Join Date
    Jun 2011
    Posts
    65
    Quote Originally Posted by Dr Dave View Post
    Dave
    Actually 10'x9' and 10'x10' are usually pretty much exactly the same price. They use the very same tracks and hardware, the 9' tall doors just use four 21" panels, instead of four 24" panels.
  10. #10
    Join Date
    Mar 2010
    Posts
    47
    Fulton County, PA
    Kioti RX6010
    Well the building is complete. Now for the doors to be ordered and installed. I am happy with the colors and the contractor that built the building. I have to do a little grading and then put stone down and then I can start filling it with my toys. I will eventually concrete everything except where the motorhome is parked.
    New Pole Building-img_0386-jpgNew Pole Building-img_0383-jpgNew Pole Building-img_0385-jpg
Similar Threads
  1. Pole building -- Pole technology discussion
    By jimgerken in forum Projects
    Last Post: 05-26-2011, 07:44 PM
  2. New Pole Building
    By SOS in forum Projects
    Last Post: 11-24-2010, 09:33 AM
  3. POLE BUILDING
    Last Post: 01-17-2010, 01:15 PM
  4. Building Plans For An Open Faced Pole Building?
    By vern6973 in forum Rural Living
    Last Post: 10-06-2009, 09:23 PM
  5. Out Building / Pole Building questions
    By NLazyA - Addy in forum Projects
    Last Post: 06-16-2008, 09:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
