Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Jun 2006
    Posts
    149
    Missouri
    1532 hydro
    Default Addition question
    I'm adding a 10 x24 addition to the gable end of this building, with the gable end 24 ft wide. What would be the best way to tie in the new slab? Should I drill through the bottom girt into the existing slab, and put a 2 ft piece of rebar into the holes to tie the 2 slabs together ? Or just pour new slab against the existing bottom girt and let it float?
    Addition question-image-jpg
  2. #2
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,039
    Central Ohio
    Kubota MX5100
    Default Re: Addition question
    If you are knocking the wall out and want the slab to be "one" with the existing slab, then I would tie it in.
    If the addition is still going to have the wall there to divide the sections and maybe just a man door to pass through, I'd let it float.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  3. #3
    Join Date
    Jun 2006
    Posts
    149
    Missouri
    1532 hydro
    The plan is to take existing gable side off, and transfer to new gable end. The existing gable end wall girts will remain with a door installed between the new and old. The new will become a work shop area with a door to isolate the two.will put osb on the current gable end gitrs to isolate the 2 portions. Hope this clears it up a little bit
  4. #4
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Has the existing slab been stable for you?
    I don't think I would worry too much about it if you can duplicate the base preparation that was done for the existing slab, and the existing slab has been stable.
  5. #5
    Veteran Member the old grind's Avatar
    Join Date
    Jul 2012
    Posts
    1,327
    Mid-Michigan
    NH T-1520 HST, JD 5210 2WD, Case DX26 HST, Terramite T5C
    Not knowing your ground saturation/freezing potential, I'd tie in the footing/slab w/rebar as you suggested. (cheap insurance?)
  6. #6
    Join Date
    Jun 2006
    Posts
    149
    Missouri
    1532 hydro
    Current slab has been stable, now where the addition is, fill will be needed. I was planning on using what we call crusher run, and using a vibrator to compact it down. It will take about 6 inches of rock compaction to get it up to the right height
  7. #7
    Super Member SPIKER's Avatar
    Join Date
    Jun 2002
    Posts
    5,000
    Ohio, Jeromesville, Ashland County
    Jinma 284
    You may need to "Remove Soil" then add back fill of a compact-able base so there is no "organic matter" under the slab.
    Keeping the exterior wall intact my be cheaper and simply add the same exterior material at the NEW gable end. You should look at the time to remove the existing wall materials, how much of it will be damaged in doing so and then compare that additional cost vs just putting in NEW and making a bigger hole where the two come together. This is what we did in a semi commercial farm building years ago.
    Drilling & sticking/Epoxy in Rebar is good choice to tie in the two slabs, heavy compaction in the joint area and NEW area WILL NEED TO BE DONE. then keeping moisture away from the joint and slabs will help keep them from freeze/thaw issues and heaving in future.
    Mark
    I may remember why I went to the other end of the shop, I'm just afraid once I get there I'll forget how to get back!
  8. #8
    Join Date
    Jun 2006
    Posts
    149
    Missouri
    1532 hydro
    Thanks for all the replies, keep them coming
  9. #9
    Join Date
    Apr 2008
    Posts
    18,039
    Central Ohio
    Kubota MX5100
    I would tie the slabs together as mentioned. I think you have a good plan with the crusher run.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  10. #10
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    19,188
    Tyler, Texas
    Several, all used and abused.
    Definitely put rebar into the existing slab. Do you have a SDS or SDS Plus rotary hammer? If not, rent or borrow one. They make drilling into concrete easy and fast. Use a good quality epoxy in the holes to hold the rebar in place.
    Are you planning on removing the existing gable wall or just adding a room onto it and extending the roofline?
    Be sure to dig your footings as deep as the existing footings. With the separate pads, freezing and moisture can create problems for you if you don't go deep enough and go down to a solid footing.
    Eddie
Similar Threads
  1. My New Addition
    By WilliamD in forum John Deere Buying/Pricing
    Last Post: 12-07-2011, 04:39 PM
  2. Question regarding the addition of hydraulic circuits
    By bigsnowdog in forum Hydraulics
    Last Post: 11-12-2011, 03:53 PM
  3. New Addition
    By waltsp in forum Attachments
    Last Post: 05-12-2010, 10:16 PM
  4. Home addition question about existing foundation
    By moss2940 in forum Projects
    Last Post: 02-20-2006, 05:09 PM
  5. Another addition
    By NJBill in forum Power Trac
    Last Post: 06-14-2004, 07:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
