Results 1 to 10 of 26
05-15-2013, 10:16 PM #1Gold Member
- Join Date
- Sep 2008
- Posts
- 446
- Location
- North East TX
- Tractor
- Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Need help finding special U-bolt or clamp???
I am installing some frost free faucets. I have a 2" water line and have a 90 degree elbow leading to the pipe on the hydrant. I want to drive a 1" cold roll rod down beside the faucet to keep it rigid and to minimize stress at the 90degree junction of PVC to metal. Because of the transition from 2" PVC to approx. 1-1/4" galvanized pipe (faucet body) The cold roll rod support will be about 1/2" away from the faucet body. Im looking for a nifty clamp of some sort to attach the support rod to the faucet. I want it to look clean and professional. I was looking through u-bolt rod clamps and found some that looked close but would not work exactly. Any suggestions? thanks
05-15-2013, 10:46 PM #2Veteran Member
- Join Date
- Jul 2009
- Posts
- 2,244
- Location
- SW WA
- Tractor
- Kubota BX2360
Re: Need help finding special U-bolt or clamp???
Do a Google image search for
safety handrail fittings
There may be some fittings or ideas you can use.
Bruce
05-15-2013, 11:08 PM #3Super Star Member
- Join Date
- Feb 2001
- Posts
- 18,770
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
The old way of doing that was to drive down a section of angle iron (paint it if you like) and attach the pipe using padded stainless steel hose clamps. If you are looking for something more dressy and finished, maybe something related to stainless steel muffler/exhaust system clamps would work.
Jim
05-16-2013, 06:18 AM #4Silver Member
- Join Date
- Feb 2011
- Posts
- 221
- Location
- Durham NC
- Tractor
- Ford 641
I had a similar problem with a 3/4" Pex to hydrant connection. My connections were in a concrete box which was a lot of trouble and may not be an easy solution. The pic shows 2 pair of treated supports wedged inside the box with the pipes bolted to them. (There two lines - well water and rainwater from a cistern.) The pipes can't move left, right, up or down.
05-16-2013, 08:17 AM #5Gold Member
- Join Date
- Sep 2008
- Posts
- 446
- Location
- North East TX
- Tractor
Here is a picture of my setup. As you can see, the transition from the 2" pipe to the faucet will prevent me from driving the rod in right down beside the upright faucet pipe. There will be a slight offset.
Im thinking something like this clamp. Whatever I use, It will have to allow for a small gap between the 1" support rod I have and the upright of the faucet. Also, it will have to allow for the difference in diameter of the support rod and the faucet pipe.
http://ts1.mm.bing.net/th?id=H.4967577332943240&pid=1.7
05-16-2013, 08:49 AM #6Elite Member
- Join Date
- Apr 2006
- Posts
- 4,571
- Location
- Wise county Texas
- Tractor
- Kioti DK 35 now
Maybe you could heat and bend your cold roll to fit the transition profile?, then use a standard clamp
Dennis
Due to recent budget cuts and the rising cost of electricity, gas and oil, as well as current market conditions, the Light at the End of the Tunnel has been turned off.
05-16-2013, 09:07 AM #7Veteran Member
- Join Date
- Jul 2009
- Posts
- 1,284
- Location
- IL
- Tractor
- B2710
Texas is probably not as cold as here in Chicago, but I wouldn't insert a good heat conductor like steel from above ground down to your source of water. I use a treated 4x4 and clamp it directly to the side of the frost proof hydrant pipe, and run it above ground to just below the hydrant valve. You can use pipe clamps and screw into the 4x4. That way when a horse bangs into it, or plays tug with the hose, the 4x4 takes the mechanical load. The 4x4 also doesn't conduct near as much heat out of the ground and up to freezing conditions in the winter. Around here frost line is 42", so I use a 6' 4x4 and it sticks up just over 2' above ground. The other thing people do around here if they're going to pour concrete around the hydrant is put a piece of 3" PVC around it at ground level going down a few feet. Then they spray rigid expanding foam into the 3" PVC to rigidly support the hydrant pipe, which gives pretty good insulation and provides mechanical support without having anything ugly sticking above the concrete finish.
B2710, LA402, PHD, 5' Ford 908 bush hog, New Idea manure spreader, dump trailer, 3PT generator, Swisher trail mower, Toro Zmaster ZTR mower
05-16-2013, 09:15 AM #8Silver Member
- Join Date
- Feb 2011
- Posts
- 221
- Location
- Durham NC
- Tractor
- Ford 641
I would drive a ~3" pipe parallel to the water pipe as far a I could and sandwich treated wood between the pipes and clamp together with U-bolts. I think the 3 incher would flex less than a 1" solid bar.
05-16-2013, 09:38 AM #9Gold Member
- Join Date
- Sep 2008
- Posts
- 446
- Location
- North East TX
- Tractor
After really looking over my setup, Im beginning to wonder if I should have tried to make a steel elbow and then transition from steel to PVC in a straight line. Most of the stress on this is definately going to be in the elbow. Your thoughts?
05-16-2013, 11:48 AM #10Silver Member
- Join Date
- Feb 2011
- Posts
- 221
- Location
- Durham NC
- Tractor
- Ford 641
Similar Threads
I need help finding a bolt
By pinkpixybug in forum Parts/RepairsReplies: 12Last Post: 03-24-2013, 04:46 PM -
Help finding 5 bolt wheel hub?
By zmoz in forum Build-It YourselfReplies: 10Last Post: 03-06-2011, 10:22 PM -
Snow Attachments finding shear bolt hole
By amaule in forum Snow RemovalReplies: 11Last Post: 03-03-2011, 06:26 PM -
source for bolt on/clamp on forklift blades for the loader on my subcompact tractor?
By FredWalter in forum AttachmentsReplies: 7Last Post: 07-06-2008, 09:54 PM -
I need a bolt on toothbar for a bucket w/HD bolt on cutting edge
By OakHillFarmer in forum AttachmentsReplies: 5Last Post: 08-15-2007, 03:55 PM
