Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Mar 2009
    Posts
    714
    Default Fencing tricks for hole depth?
    Hi Guys,
    I'm setting 12 foot treated posts 4 feet into the ground on the outside perimeter of a couple acre field. In the past, I've used a tape measure to mark the posts with marking paint and then dropped them in the hole and lined the paint mark up with the ground level. Using that technique, I found that my posts might vary in height 4 - 5 inches or more. A lot I think has to do with that you usually have a pile of dirt around the hole which makes it difficult to determine the level of the prevailing ground. Stretching a string won't work on ground not perfectly flat.
    Any tips for getting the post height to be more consistent or is what I'm seeing just how it goes?
  2. #2
    Super Member
    Join Date
    Jul 2009
    Posts
    8,994
    SW WA
    Kubota BX2360
    Default Re: Fencing tricks for hole depth?
    I once saw a fence company set posts to the approximate depth, build the fence, then trim the post tops to make them even.
    Bruce
  3. #3
    Gold Member
    Join Date
    Mar 2012
    Posts
    378
    NSW Australia
    Tractors16-600hp Farm & Earthmoving Equip, Trucks etc.
    With your post all cut to the same length it comes down to having a consistent post hole depth:
    - we use a depth markings on the auger drive shaft & limit the hydraulic cylinder travel our pcitured rig (same principles apply with a standard 3pl PTO PHD or Hyd Auger unit ).
    - As an alternative & as much speedier method of fencing, where ever practical our preference is to use a post driver - again limiting the driver hammer stroke to the desired depth for consistent post height.
    - If the post holes are already in the ground & you're trying to correct/eliminate a height variance prior to setting the posts, clear any loose dirt pile from around the post hole, measure the hole depth to the undisturbed/original ground & set/adjust the depth so it's consistent in all holes.
    - Or as BCP advises lop the posts to even up ......though the wire runs need be spot on & the post needs enough "surplus" for this to work.
    Personally, there's something that drives me crazy about fencing which is neither straight nor level - I'd much rather take a little longer & adjust to get it right than live with consequences of a "near enough" job for years (our farmhands I sure will endorse how pedantic I am on this task)
    Attached Thumbnails Attached Thumbnails Fencing tricks for hole depth?-tf-tbn19022013a-jpg
  4. #4
    Veteran Member ericher69's Avatar
    Join Date
    Aug 2008
    Posts
    1,670
    Ontario Canada
    2008 Kubota b2920
    Default
    Quote Originally Posted by bcp View Post
    Bruce
    Set posts
    Rotary laser level, mark then cut tops
    ericher69
    IAFF Local 849
  5. #5
    Elite Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Kubota 9540, RTV 900 and David Brown 885.
    Default
    How does a laser level work on uneven ground?
  6. #6
    New Member paddockbasha's Avatar
    Join Date
    May 2013
    Posts
    10
    Gresford, NSW, Aust
    Universal Farmliner, Kubota L4400D
    I have used what my Dad called a "bunyip" level. (only Australians will understand that). It's a long length of clear plastic tube with water in it. Tape each end to a tomato stake so you can keep the ends upright and not let the water run out. If setting 12 foot posts in 4 foot holes, mark posts at, say, 6 feet down from top. Then run the plastic tube between the last post and the one you are setting and make sure the distance between the water level in the tube and the 6 ft marks on the last post and the one you are setting is the same. That gets everything level if that's what you are after.
  7. #7
    Join Date
    Aug 2004
    Posts
    1,945
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    I think what most of us go for is posts that follow the terrain at a constant height. I mark my auger and have someone move the dirt away from one side of the hole to see where ground level is. My goats aren't real picky. You could have someone hold a marked stick next to the hole just outside the dirt pile to get a reference for where you want the auger head to stop. If you use a hand post hole digger to clean out the hole you can apply the same principals for consistent depth.
    Of course, if you have a sweet drill rig like MBTRAC there's no excuse for not having a beautiful fence line.
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
  8. #8
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Quote Originally Posted by Brad_Blazer View Post
    That's exactly what I do to get it as close as possible. Mark the 4' on the handles of the hand digger used to clean out the holes. Probe the loose dirt to find the native dirt and use that level as a gage. If you are building a fence, post height varies with ground elevation, but if you are building a structure, then you'll have to come back and trim the posts. You'll waste way too much time trying to make them all the same by hole depth.
    Jim
  9. #9
    Join Date
    Aug 2007
    Posts
    149
    Spotsy, VA
    NH TC40DA
    Depending on how uneven your ground is and what type of fence you are building, I think it looks better to have the top boards (and therefore the tops of the posts) all on a line and not going up and down with the contour of the land. You can get the average by setting the first post and last post and running a string tight between the two. If there are huge dips or hills, set a few posts in between on those and run the string to them. You can then use the hand held post hole digger to dig each hole to the depth needed to get the top of the posts to the same position relative to the string. However, you're setting your posts to 4' deep and I've never seen and hand held post hole digger work that deep.
    I've heard this before but now I've seen it first hand: if you cut the tops off pressure treated posts you are exposing the inside of the wood (not pressure treated) and they will rot out a lot faster than the uncut portion in the ground. This is happening to me after just six years. I've seen products advertised that you paint on to protect end cuts (Copper-Green is one) but I haven't tried them or seen them locally for sale.
  10. #10
    Elite Member
    Join Date
    May 2013
    Posts
    3,152
    Knox, In,
    Ford 3400, Gizmow ZTR, Simplicity 7016H
    Coat hanger/similar stiff metal stapled on at the four foot mark. Clear enough dirt to see hanger resting on ground...
    In fact, I bet you could rig something up outta rebar that is removable/movable to each post. Slip on, tighten at 4 foot, set post in hole, hang by rebar, fill hole/shim/concrete/whatever, remove and move to next pole...
Similar Threads
  1. 3-Point Hitch HOLE DEPTH
    By BLK6RL in forum Massey Ferguson Owning/Operating
    Last Post: 09-21-2010, 07:33 PM
  2. Post hole depth
    By Nik in forum Projects
    Last Post: 05-22-2005, 11:45 AM
  3. Posthole Digger Post Hole Digger - How to make a straight hole?
    By stephan in forum Attachments
    Last Post: 03-07-2004, 08:16 PM
  4. Stupid Tractor Tricks (As in Stupid Pet Tricks)
    By boustany in forum Owning/Operating
    Last Post: 11-01-2002, 09:29 AM
  5. Well Depth?
    By JimBinMI in forum Related Topics
    Last Post: 06-11-2000, 01:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
