rogerius
I've never seen anyone dig a flat trench and line it before gravel ,I'll bet it won't last a year with no way for water to run off it will turn into a mud pit , and why would you start laying the cloth on the flat section instead of the hill first ? I wouldn't have dug down at all instead I would have built up and added run off from the center with drainage trench on each side to carry water away from it ,The way it looks to me is the water will run into it and mud city here you come .I hope it works out for you .
Thanks for your toughs Grumpy Old Man. Reading here on the forum, most of the guys were saying to not use the fabric on the hill for couple of reasons: the track will pull it off when will go on the hill, the gravel will run down the hill on the fabric and the most important thing, the water will not stay on the hill so the soil will not get a chance to mix with the gravel. About the mud pit, yes, that is a valid point as long the driveway is not compact properly but, your suggestion to build up on the existing soil I'll not buying at all. That is a big mistake if the soil is not clay or something strong. A driveway without a solid base is a non sense and in order to create a good base is to remove all the organic material. About the trench, I'm planning to dig it maybe later when the time permit and only if really will be required.
