Results 1 to 5 of 5
  1. #1
    Join Date
    Nov 2012
    Posts
    96
    Land Between the Lakes
    John Deere 3038e and LS K 5047
    Default Run off from pond/road tile....
    Anyone have a picture of how you manage overflow of the pond water coming thru a tile to a hillside(dam)....?
    We put in the tile to stop the pond overflowing over the drive across the dam.... now, I need some serious water management on the downspout side...it is rutting the dam bank....
    Run off from pond/road tile....-img_1017-jpg
    John Deere 3038e
    Kentucky
  2. #2
    Gold Member
    Join Date
    Sep 2007
    Posts
    494
    Northeast Ohio
    JD 5105, IH-Case 255, JD 3038E
    Default Re: Run off from pond/road tile....
    Best to extend the pipe down the dam and to a proper outlet at a lesser grade. You do not have any head pressure on the pipe for it to run full since it is so close to the top of the dam. More info on when and how the pond was constructed would be helpful. Doesn't look like it was designed properly.
  3. #3
    Join Date
    Jan 2008
    Posts
    2,384
    Western PA
    John Deere 5083E MFWD, Kubota L3400 HST
    You need to dissipate the energy from the flow. How you do that is up to you, but gravity+water=serious power. The two most common ways of doing this are with riprap or larger stone in a depression down the slope to direct the water. The other way would be to continue the pipe down the slope and run into an energy dissipator at the toe of the slope.
    Now my concern would be the culvert. Thats going to seriously limit your overflow capacity. I would suggest redesigning it for a spillway depending on how large your pond is. Just my 2 cents
    '11 John Deere 5083E, 563NSL Loader, MX10 Mower, 78" Bucket, Forks/Bale spear (interchangeable)
    L3400 Kubota HST Loader, finish mower, rake, scraper blade, Gin pole, Kustom Fab front hydraulic snow plow (Inspired by ASGAR)
    JD 550 Dozer 6 way blade and winch
    JD 450B Track Loader
    Case 480C Backhoe W/ Extend-a-hoe
    '01 International 4700 LP, DT530, Allison MD3060, Air Ride, Crew Cab
    '11 Moritz 20+5 14.5K GN with adj. Tail
    ''08 700R Raptor
  4. #4
    Super Member SPIKER's Avatar
    Join Date
    Jun 2002
    Posts
    5,000
    Ohio, Jeromesville, Ashland County
    Jinma 284
    Most likely cheapest and most effective way is to pour a nice concrete trough to take the water down the dam. It would make a nice sled run in winter too lol. The Rip Rap is OK too BUT leaves the "dam earth WET" underneath it and not good for a earthen dam . Other methods are to pipe it with some plastic culvert all way to bottom and out far enough to keep the dam dry. it would not have to be buried but would make "dam grass management" easier.
    Now you can check and see if there are any "DAM MANAGEMENT" classes at the local ag/DNR extension too
    Mark
    I may remember why I went to the other end of the shop, I'm just afraid once I get there I'll forget how to get back!
  5. #5
    Join Date
    Nov 2012
    Posts
    96
    The pond is small.... just wider than the picture and extends to the trees in the back ground...
    The tile did good.... we got 5 inches of rain in 8 hours about a month ago... and it did not overrun the levy(road)....the 12 inch pipe held it... but man.... cut a gash in that bank....
    has anyone seen a rubber mat that goes down under the rip rap... that keeps the bank dry and helps funnel the water to bottom,
    thanks for replies...
    John Deere 3038e
    Kentucky
Similar Threads
  1. To keep and repair or run away?
    By suprnova in forum Parts/Repairs
    Last Post: 06-21-2013, 11:58 AM
  2. won't run after new manifold
    By Terry N in forum Parts/Repairs
    Last Post: 05-23-2013, 10:15 PM
  3. anyone run a 2 bottom with theur 235?
    By brown1 in forum Bobcat Tractors
    Last Post: 05-18-2013, 05:08 PM
  4. troy built with briggs moter no run
    By sam5570 in forum MTD
    Last Post: 05-02-2013, 06:54 AM
  5. Replies: 30
    Last Post: 01-04-2007, 09:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
