Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Gold Member RxRatedZ71's Avatar
    Join Date
    Feb 2010
    Posts
    251
    Edmond, OK
    JD 3203
    Default Drainage ditch using a MB/SS.
    We had a strong thunderstorm drop 8+" of rain back in May and it caused our creek crossing under our driveway to flood. Our downstream side of ourtin horn's wingwall also started to erode away. I realized that we are getting all of our neighbors water off his land, onto ours and down our driveway, into the creek, then back across his part of the creek. Ive decided to cut a drainage ditch along the side our our proporty to contain and channel the water into the creek and avoid the driveway entirely. I got a quote from a dozer guy for 2 machines for a day for $1800 then the price of rock for check dams and bank erosion control.
    Ive decided to conquer this with my tractor on my own. Our Dave Ramsey budget plan didnt allow for the other option. So I bought a middlebuster yesterday and plan to make it into a subsoiler as well.
    Drainage ditch using a MB/SS.-forumrunner_20130718_093042-png
    Poor timing and lack of planning on your part do not constitute an emergency on my part!
    JD 3203, 300 series loader, Frontier rotary cutter, Frontier boxblade, quick-attach bucket, Polaris Sportsman 600, Cub Cadet lawn tractor
  2. #2
    Join Date
    Feb 2010
    Posts
    251
    Edmond, OK
    JD 3203
    Default
    Ive got to find a shank for the subsoiler tip (or make one). Any suggestions? I called the mfc to see if their SS shank would fit but the MB angle is different and the tip is $30+.
  3. #3
    Join Date
    Aug 2003
    Posts
    93
    Aurora, OH
    JD 4120, X595, Cat 259D Ctl
    Default Re: Drainage ditch using a MB/SS.
    AgriSupply.com carries all kinds of tips and points. Prices seem very reasonable.
  4. #4
    Join Date
    Feb 2010
    Posts
    251
    Edmond, OK
    JD 3203
    Default
    Good point. Ive used them before for mower blades and chemicals. Great place and friendly people. Thanks for reminding me.
  5. #5
    Join Date
    Aug 2012
    Posts
    179
    Back in Texas soon, I hope
    Kubota MX 5100 Cub Cadet LGTX 1050
    I switched a similar plow from MB to SS a while back, since I had access to a used chisel point, and it worked just fine. I had no idea there were different angles involved. Ignorance is bliss, I guess. Might be worth giving it a try.................
  6. #6
    Join Date
    Feb 2010
    Posts
    251
    Edmond, OK
    JD 3203
    Default
    I thought about just cutting a tip from some 2" flat strap from TSC. I thought 1/2" might be thick enough. I know it probably wont last as long as a hardened tip but its only $12 for a 3 foot piece and I only need 8" for each tip. It more or less just bolts over the angled tip of the frame and protects it. They are ordering a potential tip for $38...we will see.
    I made some good progress with the box blade pitched down on one side. Once the phone guy came out and laid a temp line I really began to make some progress.
  7. #7
    Join Date
    Feb 2010
    Posts
    251
    Edmond, OK
    JD 3203
    Default
    Well the point didnt fit so I just bought some 3/8" flat bar and cut a point for myself.
    Drainage ditch using a MB/SS.-forumrunner_20130725_080545-png
    Drainage ditch using a MB/SS.-forumrunner_20130725_080628-png
  8. #8
    Join Date
    Feb 2010
    Posts
    251
    Edmond, OK
    JD 3203
    Default
    Here is a pic of some progress. I tried the middle buster which performed great. I had to modify my SS point b/c it didnt extend far enough beyond the base of the frame. When lowered, it just sat on the surface rather penetrate the ground. I just drilled a hole close to the end amd spun the point around, thus allowing about 1.5-2" to hamg over. Now it works great. I think im going to weld some sort of wedge onto the main support to cut better with less disturbance.
    Drainage ditch using a MB/SS.-forumrunner_20130725_082758-png
  9. #9
    Gold Member
    Join Date
    Oct 2010
    Posts
    385
    Tidewater VA
    John Deere 3320
    Looks great. Thank you for this thread as I have this issue times four and had never heard of or seen a "middlebuster". Jim
  10. #10
    Join Date
    Apr 2011
    Posts
    740
    SW Ohio
    John Deere 3032E
    this spring when the lawn was soft I just used my FEL and did the same thing
    I got with the neighbor and we started in his yard and ended in mine by the front ditch that runs under the road and into a good size creek
    the last few years it would be middle of June before I could cut the grass in that area now 2 days after 2" of rain I'm in there cutting
    made all the difference in the world
    I do need to get some rock in there to keep erosion down
    does anyone have suggestions what would be best to use
    Thanks in advance
Similar Threads
  1. Drainage Ditch Crossing
    By Beltzington in forum Rural Living
    Last Post: 09-06-2011, 10:36 PM
  2. Drainage ditch construction
    By DJB132 in forum Owning/Operating
    Last Post: 04-20-2009, 04:57 PM
  3. Clearing a drainage ditch...
    By BillCroasmun in forum Power Trac
    Last Post: 08-05-2005, 11:23 PM
  4. Creating shallow drainage ditch
    By blakesfav in forum Projects
    Last Post: 07-02-2004, 06:22 PM
  5. Drainage ditch - gravel first or not?
    By PaulT in forum Projects
    Last Post: 10-16-2001, 07:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
