Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
  1. #1
    Platinum Member lzicc's Avatar
    Join Date
    Jul 2009
    Posts
    563
    Pittsburgh, Pa
    Kubota B2650
    Default Need some suggestions on basement drainage
    I built an addition on my house. It is 24' x 32'. I dug the foundation out, poured the footer and laid the block. I have the addition all framed in, all the gutters installed which drain through PVC pipe that goes to the street. I put an exterior french drain around the perimeter, backfilled and have the dirt sloped away from the house. I am getting ready to pour the basement floor when I noticed water on the ground. I don't know where the water is coming from, but it doesn't look like it's coming through the blocks since they are dry but seeping possibly under the footer. You can see the water in the one end of the basement and it wicks up the footer. It's not allot, but you can see shallow puddles. The ground there is mushy also. It seems like after it rains real hard, about 4 days later the water shows up. It dries up on it's own after a week. The footer is on solid ground which is shale. My backhoe had trouble digging the footer so I rented a demolition hammer to break up the shale for the footer so I know it is solid.
    I would like to know how this water is getting in, but I don't have any idea. I am going to put in an interior french drain around the perimeter. I have a few options. Where I built the addition, there is an old well pipe that is in the middle of the basement floor. I cut it off level to the ground and was going to cap it and pour my floor over top of it. The well is about 70' deep. I thought about running my perimeter french drain to it so that the water will drain into the old well. Is that a stupid idea? What would be a better drain pipe to use, PVC or Flex pipe? When I go to pour the floor, would it be a good idea to put a good layer of gravel or limestone on the surface? Right now I have a small layer of limestone covering the surface, but may be putting a thicker layer on since I saw the water. I guess I would put the vapor barrier on top of the limestone not below it?
    Kubota B2650 HST - LA534, BH77, 60" BoxBlade
  2. #2
    Join Date
    Aug 2008
    Posts
    1,555
    Barrington, NH
    Bobcat CT230
    Default Re: Need some suggestions on basement drainage
    1. Do not ever try to run a drain into a drinking well pipe, no matter how old it is. You'll contaminate the drinking aquifer and you don't even want to think about how much the government will fine you for it. We're talking 7 figures minimum. They will destroy you. And if they don't, your neighbors will, and with justification.
    2. I hope you put your footers below the frost line. Otherwise, that water will freeze in the soil and destroy the foundation of your addition.
    3. I'd recommend digging out around the foundation, applying a heavy sealant to the outside (asphalt?), laying 6 inch drain pipe all around, bury it with at least a foot of 1.5 to 2.5 inch gravel, and cover the gravel with fabric before covering with soil.
  3. #3
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,291
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    This issue requires pics of the site during construction so we can see where you might have gone wrong, and so we can advise what to do to remedy it. NO to water down old well!
    You may end up having to re-excavate outside to seal the walls and footing area from groundwater penetration. Sounds like you also have rising water table from rainfall, and you will definitely have to seal off any existing water which is showing up in the basement, PRIOR to pouring any kind of floor. Yes to vapor barrier on top of final subfloor surface, for VAPOR, not liquid ~ water.
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  4. #4
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Pics always help.
    x3 on don't use the well.
    I'm not sure you have done anything wrong, you just haven't done enough yet maybe. The outer perimeter drain is not going to collect water that seeps up in the floor area inside the footer and foundation walls, there is no good path for the water to get there. It would have travel under or through the footer and/or wall to reach the drain.
    You have some extra water to deal with is all. Now is the time to do it. It is possible you could pour the floor over a good vapor barrier and not be bothered, bt you would be taking a chance that is more difficult and expensive to fix after the slab is in place.
    You are on the right track with the under the floor drain pipe. It needs to be installed in a bed of washed gravel about 8" deep. If radon is an issue in your area, the radon abatement piping would also be in that bed of gravel. I hope you have enough depth to not cut into your basement ceiling height too much if you add the gravel.
    The water you collect in the under the floor drain pipes is best sent to a sump pump pit IMO since you want the water no higher than the base of the footer ideally.
  5. #5
    Platinum Member atgreene's Avatar
    Join Date
    Aug 2007
    Posts
    873
    Sebago, Maine
    2005 TB135 Excavator with Thumb, Quick Attach System, Ripper tooth, 3' Hydrauic Tilt Clean-up Bucket, Skeleton Bucket, 1986 Kubota 4150 with Loader and Quick Attach with Woods Forks, JD B, 1963 IH 504
    If you havent poured the basement floor yet, then you shouldn't have any issues if the drain lines are at the footer. Once you bring the floor up to the footer with crushed stone and lay plastic, the water can't push up through the floor without first seeking the path of least resistance, which should be the drain pipe.
    FWIW, when I do foundations or footers, we always use 6" slotted filter wrapped pipe. It's not mush more than 4" and will handle loads of water and silt if you ever have a silt infiltration issue.
    Also, I only use crushed stone as my fill under any concrete. Water will travel under the conrete through the stone to find the path of least resistance which will be the pipe.
    2009 Kubota M7040, cab
    2005 Takeuchi 135 excavator
    1963 Oshkosh 4819
    2013 GMC 3500 6.0 w 9-2 Boss V Fisher poly Sander.
    IH 504, JD B, Ford 2n, Farmall cub, Gehl 1475 Round Baler, JD 640 rake, Vermeer 2500 Bale Wrapper, Zetor 185 Drum Mower, New Idea 217 manure Spreader, Kuhn 4 star tedder, Farmi 501 winch.
    Local 740 Portland ME
    20 Scottish Highland Beef Cattle, 3 Herefords, 3 Goats, 2 Alpacas, 2 Llama, 140+- layers, and lots of maple trees.
    Facebook: Phillip View Farm
  6. #6
    Join Date
    Dec 2006
    Posts
    1,438
    Coastal Rhode Island
    Jinma 354, purchased 2007
    How deep is your exterior french drain?
    When it rains, some of the water flows over the ground, most soaks into the ground. From there some is retained by the soil, some makes its way down to the aquifer, some emerges in ponds, streams and rivers. It moves sideways and down. Since the well is 70' deep you're not really hitting groundwater, you're hitting rainwater that's making its way somewhere. You need to give it a better path than through your basement. The best way is to have exterior perimeter drains below floor level, and then either basement walls with a waterproof basement exterior or an excavated trench filled with gravel that redirects flowing water at any level down to the drains.
    Interior drains work -- I have them in my house -- but they're a poor second choice because they do little to protect your walls from hydrostatic pressure.
    If possible, the best outlet is to have the drains flow at a 2% drop until they emerge at grade. A sump pump is a poor second choice, sump pumps fail all the time, gravity has been working continuously for billions of years.
    Agree with the others that you don't want to be putting anything down the well, that's seriously illegal almost everywhere, a bad idea everywhere.
  7. #7
    Join Date
    Jul 2009
    Posts
    1,821
    IL
    B2710
    Quote Originally Posted by lzicc View Post
    You need to properly abandon a well according to the local legal requirements, which probably means grouting it. You should have a licensed well contractor do that for you to avoid future liability and resale problems. Many people in the area, probably including you, are vulnerable to contamination of an abandoned well even if you don't deliberately dump something in it.
    Kubota B2710, John Deere X738 snowblower, Toro Zmaster ZTR, King Kutter bush hog, New Idea manure spreader, Swisher trail mower.
    Lincoln Square Wave 200, Lincoln 225 AC/DC, Harris Oxy/Ac.
  8. #8
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Quote Originally Posted by quicksandfarmer View Post
    I have both a grid of interior drains and exterior perimeter drains. They don't serve the same area though is the way I picture it. Assuming the OP's exterior footer drains are deep enough, as you asked, then obviously they are not removing the water that is seeping up inside the foundation, or it wouldn't be there. Pouring concrete over it isn't going to change that, not that a lot of basement floors aren't poured over wet ground.
    It really depends on how much water is there as to whether it will become a problem. That's the tricky thing about home construction, someone says "I did it this way, or I've always done it this way and never had a problem." Yet, there are more than a few wet basements.
    Sump pumps do fail, but so do gravity drains. They can get clogged, get roots in them--although that should be rare anymore with plastic pipe, get crushed, etc. It's easier to replace a pump than to repair a bad gravity drain that is at the bottom of a basement foundation. It depends also on what good options are available as to where the sump pump water is going to go.
    In the event of a flood or plumbing disaster, a sump pit is a built-in basement floor drain. Sumps pits are bad for radon control. They both have pluses and minuses.
    How ever you get there, the ideal slab is one that sits high and dry.
  9. #9
    Join Date
    Jul 2009
    Posts
    563
    Pittsburgh, Pa
    Kubota B2650
    Thanks for the heads up on the well.
    My footer is about 5' below grade. The french drain is 4" perforate pipe. I have landscape material on the bottom with a layer of gravel on the bottom and about 1.5 feet over the pipe with landscape material over top that. The pipe runs next to the footer on the side.
    I shouldn't have any water is this basement with the way I graded the landscape and how the french drain was put in. Really odd. It only happens when we get a good rain and even then it takes a few days after the rain for the water to show up in the basement. The rest of the basement is dry, it is just the one corner/side of the basement. I wasn't going to put an interior drain in, but might as well now. I can put a sump pit in for that. I just want to make sure that once I pour the floor that I don't get any dampness.
  10. #10
    Platinum Member Dr Dave's Avatar
    Join Date
    Feb 2012
    Posts
    849
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    Were does your exterior french drain water go?
    If you put a sump pit in get a sealed unit with a vented cover, for radon venting, and dont use as a floor drain.
    The well needs to be capped and sealed by a well guy, then reported to the state.
    After the slab has cured, calk the perimeter, this is often skipped.
    Dave
Similar Threads
  1. Crickets in the basement - They've got to go!
    By MossflowerWoods in forum Rural Living
    Last Post: 12-01-2012, 06:37 AM
  2. Drainage Suggestions
    By LoveTheSmellofDiesel in forum Projects
    Last Post: 06-20-2011, 10:10 AM
  3. Basement remodel help/suggestions
    By papabear in forum Related Topics
    Last Post: 12-21-2004, 10:40 AM
  4. anyone try to dig a basement under House?
    By megotatractor in forum Projects
    Last Post: 12-03-2004, 11:05 PM
  5. Open runoff drainage ditch- Suggestions?
    By DiskDoctr in forum Projects
    Last Post: 07-12-2004, 09:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
