TractorGuy
Elite Member
- Joined
- Sep 15, 2013
- Messages
- 4,611
- Location
- N. FL
- Tractor
- John Deere 4310 CUT, Ford New Holland 575E Industrial Backhoe, John Deere F725 Front Mount Mower
This is the first project I've done with my new to me 855 JD. My wife planted this tree many years ago right between the septic thank and drain field. Guess why I needed to dig it up?
I started digging with a dirt scoop and while I had dug around pretty good the tree was still solid in the ground. I had it in my mind I was going to build a 2" receiver type hitch and make various attachments I could use in it. I ended up buying the hitch off ebay but at the end of the day I should have built my own. The one I got is usable now that I welded patch plates on the top link holes with the proper 3/4" holes. The one I got had loose shards of metal not removed from cutting and the idiot bored 7/8" holes in the top link connection. I bought a 3' piece of 2" square tube with 1/4" walls. Milled out some offset holes for a piece of 1"x2" SS bar I had laying around. I cut an angle on one end of the bar and drilled the bar and tube for a pin or bolt. I used this to dig around the tree and break many of the roots loose, then wrapped a chain around it and tugged and pulled till it came up. I plan to try to replant it in a different location.
We cut this tree back to nothing a couple of years ago and it had already grown over 20 feet tall. I cut it back again before I started digging on it.
