Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Gold Member
    Join Date
    Jan 2012
    Posts
    252
    Moores Hill, Indiana
    MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader
    Default Electrical wiring question
    So I ran an underground wire to one of my sheds off of another electrical box. I installed a new small breaker box in the shed, it only has two breaker slots. Its the weirdest thing though. One of the breaker slots work perfectly, but the other does nothing. I've switched the breakers and wires around and no change. The slot on the left of the box works, but the right doesn't. What in the world could I have done wrong?
    MBA = More Bad Advice
  2. #2
    Super Star Member murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    15,810
    Ohio
    Kioti DK 40-Massey ferguson 135-Ventrac 4500 Diesel
    Default Re: Electrical wiring question
    how many wires wire in the line you ran? what color are they? did you run a neutral?
    Murph ------------
  3. #3
    Super Star Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    12,772
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by crowbar032 View Post
    Normally the left breaker (if 120 volt) will be on one leg of the 220 to Neutral and the other breaker will be on the other leg of the 220 volt to Neutral. You did run 3 wires Hot Neutral Hot to this other box correct? and you did measure to see that you have 220 volts between the legs and 120 volts from each leg to Neutral, correct?
    If all of that is correct, take both breakers out and inspect where they connect up to each leg.
    James KUA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner How to add a link to a post . Best way to search TBN
  4. #4
    Join Date
    Jun 2009
    Posts
    12,772
    Branson, Mo.
    A photo would be worth... oh, about a thousand words...
    James KUA
  5. #5
    Join Date
    Nov 2011
    Posts
    15,810
    Ohio
    Quote Originally Posted by k0ua View Post
    That's why I asked how many wires were ran..
    Murph ------------
  6. #6
    Join Date
    Jun 2009
    Posts
    12,772
    Branson, Mo.
    Quote Originally Posted by murphy1244 View Post
    You wanna lay a wager on how many he ran?
    James KUA
  7. #7
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    6,362
    north idaho
    dk45se hst cab
    yup....i can see it right now. one side of the panel has no power. If you want to keep it 120 volt but have 2 circuits, you can jump both sides of the main. however if you only ran 20 amps to the panel, you wont have any benefits of having 2 separate 20 amp circuit breakers.....you still have only 20 amps , 120 volts going there...need pics, wire size info, wire type info, what sized service you ran and how large of a service you are feeding from.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  8. #8
    Join Date
    Nov 2011
    Posts
    15,810
    Ohio
    I kinda had a feeling.
    Murph ------------
  9. #9
    Gold Member
    Join Date
    Jan 2012
    Posts
    252
    Default
    I ran 3 wires. Pic should be attached.
    Attached Thumbnails Attached Thumbnails Electrical wiring question-forumrunner_20140405_201125.png
  10. #10
    Gold Member B7510HSD's Avatar
    Join Date
    Apr 2008
    Posts
    387
    Renton,Wa./Long Beach Wa.
    Kubota B7510HSD
    It looks like the breaker on the right goes to where the white neutral wires are??????? maybe it's just the way the photo looks I hope!!
Similar Threads
  1. electrical wiring harnesses - where
    By maizeandblue in forum New Holland Owning/Operating
    Last Post: 03-24-2013, 07:50 PM
  2. LS Electrical Wiring Question
    By Forfar in forum LS Tractors
    Last Post: 08-18-2012, 09:35 PM
  3. Looking for electrical wiring.
    By trygta in forum Parts/Repairs
    Last Post: 04-06-2011, 03:31 PM
  4. Electrical wiring question
    By Richard in forum Rural Living
    Last Post: 02-17-2005, 09:48 PM
  5. Electrical wiring question
    By Gary_in_Indiana in forum Rural Living
    Last Post: 06-20-2002, 09:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
