spindlewood
I don't understand what the winch is supposed to do? Once the tree is on the ground, does it pull it closer to the tractor before you drag the tree with the tractor? Or is it to get it into position, then you hook up your chain and drag it with your tractor? ... Why not just use a chain?
Eddie
In my area , trees grow where tractors don't go...
It helps to get the tree a bit closer before you chain on. That is, It helps to keep the tractor upright or up past the axles in mud ;-)
As in my part of the world, the tractor needs to stay up on the ridge road, and the logs are down in the "draw". in other words they are downhill on either side of the ridge road. If you get the tractor down there, you will need a tow truck to get it back up. You need to get the logs up to where you can then haul them off.
Eddie,
CalG & James have pretty much said it. My 27 acres is mostly on a hillside with a river below. The tractor has very limited access on the hillsides and also limited access in the riparian zone - both because of mud and lack of road. I can imagine using ingenuity to find ways of pulling logs 90% of the time with the drawbar. There will be situations where a simple winch pull will be the obvious solution due to terrain constraints.
I am curious if you simply use the drawbar to attach logs to or if it would be a good idea to have something more durable on the 3pt to attach to and allow for lifting the head of the log. I came across a Tractor Drawbar Trailer Hitch for $99 - good idea / bad idea / other ideas?
Also for $99 w/ Standard 2" receiver: Titan Trailer Receiver Drawbar Hitch
