Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Elite Member /pine's Avatar
    Join Date
    Mar 2009
    Posts
    4,698
    Default Re: Outhouse for convenience
    Quote Originally Posted by BHD View Post
    Like a hole in the ground,
    not if you live downwind...!
    Slash Pine
    blunt and succinct but sincere...in the immortal words of Popeye..."I yam what I yam"
  2. #12
    Gold Member
    Join Date
    Jun 2008
    Posts
    385
    -out-house4-jpg
    I have a home brew composting toilet on my weekend farm. It has been in use for about 4 years before I emptied it a few weeks ago. I simply dug a good size hole and built a small shed over it. I then got some formwork ply as a floor. The throne is a 20ltr drum with the bottom cut out with a box built around it. This is screwed to the floor which has the appropriate cut out.
    It has a chimney coming from under the floor with two 12v computer fans. One is attached to a small PV panel and the other to a controller that turns the fan on for 1 minute every 10 minutes. This is powered up when I turn on the battery bank for my camp.
    Next to the throne is a bucket of sawdust. You can work out what this is for!
    The picture looks like someone needs to improve their aim but is simply because the hole in the floor is not big enough and moisture dribbles down the inside onto the floor. The new floor is better!
    This has handled weekends with over 20 people without any complaints of smell. The material removed was just crumbly compost that I buried nearby in the bush.
    Weedpharma
    There are 10 types of people who understand binary, those who do and those who don't.
  3. #13
    Veteran Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    2,001
    central Iowa
    JD 2720
    You probably will need a permit for a working outhouse and they are about as easy to buy as hen's teeth. I think I would build something that looks like a small portable shed. It'd be less likely that the DNR would be interested that way.
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  4. #14
    Gold Member
    Join Date
    Jun 2008
    Posts
    385
    The local council may not allow mine as a fitting in a residence but this is just a weekender.
    If this "shed" is built in the back paddock for ocassional use I would not expect any problems. It beats digging a hole every time.
    Weedpharma
  5. #15
    Veteran Member grnspot110's Avatar
    Join Date
    May 2007
    Posts
    1,406
    MO
    John Deere 790, 420, 314, "L/60" Custom & 70 I
    I built my own, mostly with used lumber:
    -farm-006-copy-jpg
    -hpim1084-small-jpg
    Hole in the ground is lined with an old water heater tank with the ends cut out. Toss a little wood ash in the hole occasionally for odor control. ~~ Lowell
  6. #16
    Join Date
    Dec 2009
    Posts
    1,425
    Kansas...USA
    Kubota B2620 (2012)
    Seems like it depends on who and how often the convenience is needed. If it was just me on the back of the "farm" a bucket with a seat adapter, a couple tires over a hole, a log.......just about anything would do er do do.
    Kubota B2620 HST
Similar Threads
  1. Convenience items added to JD 4200
    By mjncad in forum Customization
    Last Post: 05-30-2011, 08:50 PM
  2. M Series-Convenience Hydraulic Lever
    By Turkeyman in forum Kubota Buying/Pricing
    Last Post: 01-16-2011, 02:28 PM
  3. Our Outhouse
    By coreshot in forum Projects
    Last Post: 12-01-2009, 11:19 PM
  4. A simple convenience item.
    Last Post: 06-21-2009, 10:44 AM
  5. outhouse
    By 1948berg in forum Photos
    Last Post: 02-16-2007, 05:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
