Results 1 to 9 of 9
  1. #1
    Member
    Join Date
    Dec 2012
    Posts
    36
    STOW,MA
    KUBOTA L3940HST BACKHOE
    Default Best sealer for pole barn
    It's built at 60x38 pole barn with 16' foot sides. What is the best sealer to keep natural wood color with no gray fading. Thanks mark
    Attached Thumbnails Attached Thumbnails Best sealer for pole barn-image-2002834885-jpg
  2. #2
    Super Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    6,650
    Virginia USA
    Kubota L3200 Deere X380 Kubota RTV-X
    Default Re: Best sealer for pole barn
    You can use something like Thompson water seal. I've heard of it used on decks and fences, so siding should be fine too. I used it on a bench and it still looks new after 2 years. You will need to reapply after a couple years I think.
  3. #3
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    19,380
    Tyler, Texas
    Several, all used and abused.
    I would go to a specialty paint supply store like Sherwin Williams and get the best they have to offer. Most sealers are very short term and focus more on repelling water then preserving the natural color of the wood. I'm not even sure that's possible without a stain.
    Eddie
  4. #4
    Join Date
    Dec 2012
    Posts
    157
    Johns Island, SC
    Ford 1920, JD LT180
    I did a lot of reading on this when it came time to stain my deck (ContractorTalk.com is a great resource), and I ended up ordering 5 gallons of stain from TWP. They have a "natural" color selection, but I went with "Cedar".
    TWP Stain Sealer | Wood Deck Preservative
    You will need the 1500 series if you live in a "Green" state, as the original 100 series had too many environmentally bad ingredients.
    My deck looks great with this stain, and although it faded, it is on its second full year and still beads water on the surface. Vertical surfaces are easier to protect as the water doesn't sit on them for hours on end.
    Thanks,
    Joe
  5. #5
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    9,119
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    Read around, TWP is among the best. Thompsons is vastly overmarketed.
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  6. #6
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Quote Originally Posted by EddieWalker View Post
    Eddie
    It's is hard to keep a natural wood color. I tried with western red cedar clapboards and it didn't work out well. Eventually you get UV caused color changes and you will see every little fleck of black fungus and accumulating sooty stains.
    As Eddie says, you may need to use a stain that simulates the fresh sawn wood color. You realize that is not a "natural" color of exposed wood? It wants to be something else color-wise.
    Sherwin Williams has a good reputation. I had good results with Cabot semi-opaque stains.
  7. #7
    Join Date
    Dec 2010
    Posts
    213
    Rural NoVA
    Now is the time to fight the carpenter bees. If you don't already have them, you surely will.
    2007 JD 5625 | 1997 Bobcat 751C | Walker MT26
  8. #8
    Super Member tcreeley's Avatar
    Join Date
    Feb 2011
    Posts
    7,957
    Hudson, Maine
    2003 NH TC30
    I like Cabot oil based stains - soak into the wood and don't sit on the surface. Semi solid works great color wise unless it is exposed to a hard direct sun year after year. Then the solid is a much better choice and holds its color well. Next to no scraping between coats years apart, -just stain again- brush, roller, spray. I love the stuff. Once you start with cabot you should stick with cabot. Other brands often don't adhere well to cabot. Also, cabot keeps all of their old formulas, or if you give them the one you wrote down 10 years earlier, they will remix it. I've also applied it at temps in the 40's with freezing overnight. Did fine- just longer to dry.
    NH TC30, 7308 loader, 7' snowbear plow, 5' hiller, 5' tillovator (agrisupply), International Agritech 5' towable Bushhog. dumping carryhall, camo brush trailer, 8 hp Trencherman backhoe, International disk harrow, International single plow, Sears ZTL 7000, 8hp Roto Hoe Shredder'nChipper, CubCadet 524 snow blower, CubCadet rear tine tiller, working forge
  9. #9
    Join Date
    Mar 2005
    Posts
    1,429
    Richfield, Wi
    Resident Architect
    Any clear product will be short lived. It's the pigments in the sealer that actually gives it the life. When you start checking the warranties you'll see a correlation between transparency, cost and life expectancy.
    Turbo Yanmar 1110d, 4wd, powershift, kwick-way loader SOLD
    Waldon 5100, Cummins 4b SOLD
    Gehl 6635 skid steer - Faver grapple, forks, bucket, trailer mover
    Toro 328 4wd mower, 72" Lastec Deck & Toro 150 snowblower SOLD
    Toro 3500 3wd mower
Similar Threads
  1. Pole Barn vs Metal Barn....pros and cons?
    By markmc in forum Projects
    Last Post: 08-16-2015, 06:59 PM
  2. Replies: 11
    Last Post: 07-11-2014, 11:47 PM
  3. Pole Barn, Pole Question
    By HoustonBrama in forum Projects
    Last Post: 07-27-2008, 05:15 PM
  4. pole barn pole problem..
    By mopower440 in forum Projects
    Last Post: 12-15-2003, 06:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
