sodamo
Super Star Member
- Joined
- May 20, 2004
- Messages
- 16,982
- Location
- Big Island, HI
- Tractor
- LS XR4140H (Mine) BX2380 (wife’s)
Pool is L shaped, about 39k gallons. Not looking to do a major heat, but my thinking is if I can achieve maybe 3 degrees or so above air temp then ought to be pleasant.
Not being in postcard Hawaii, our daytime temps average in 70's. Yearly low, a rare 59 and high of 81. Want to hook a solar heater loop into the pump line. This pump will be solar controlled - if sunny, should be pumping. First attempt at such a project so willing to listen and learn. Yes, a budget project .
So, I have some 1 inch black poly pipe. Used some pvc fittings to make the turns., fastened with SS clamps (not installed yet on near end) Need to anchor and neaten up, but here is start I got today.
Any suggests/advice/discussion welcome.
David Sent from my iPad Air using TractorByNet
