Results 1 to 3 of 3
  1. #1
    Silver Member Tony H's Avatar
    Join Date
    Mar 2013
    Posts
    132
    Summit, NY
    JCB MIDI CX
    Default 4" Valve in pond for future gravity feed Garden watering
    I've been running two garden hoses for about three months to get the water level in my pond down low enough to feel I will not have any Winter Freeze problems with this pipe.
    The idea is to have a gravity fed water source for a future garden. It is down hill from the pond so it should work well.
    The shadowing is bad on the one picture that shows the use of the 9" bucket to cut a deep but narrow path into the side of the pond. Then I switched to the 18" bucket and dug a wider trench to facilitate the Plexiglas anti seepage barrier.
    one pic shows the closeup of the assembly Pipe runs through the plexiglas and is all glued tight so water can't seep down along the pipe.
    Another picture shows the Larger blue pipe that runs vertical, that is my access to the valve after totally backfilled.
    That white stuff on the slope to the water is Sodium Bentonite.. basically powdered Clay for added insurance I have no leaks.
    I haven't finished the 160' run but at least the valve is in and the Pond wall is water tight.
    Attached Thumbnails Attached Thumbnails 4" Valve in pond for future gravity feed Garden watering-img_3346-jpg   4" Valve in pond for future gravity feed Garden watering-img_3335-jpg   4" Valve in pond for future gravity feed Garden watering-img_3339-jpg   4" Valve in pond for future gravity feed Garden watering-img_3340-jpg   4" Valve in pond for future gravity feed Garden watering-img_3342-jpg
    4" Valve in pond for future gravity feed Garden watering-img_3344-jpg   4" Valve in pond for future gravity feed Garden watering-img_3333-jpg
    JCB MIDI CX :
    4:1Bucket
    Front Mount Log Splitter
    Virnig SBV84 'V' plow a wonderful tool
    Cub Cadet :
    42" snowplow
    Custom 2" Receiver Hitch
  2. #2
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    19,388
    Tyler, Texas
    Several, all used and abused.
    Default Re: 4" Valve in pond for future gravity feed Garden watering
    Just for extra insurance, you might want to pure concrete around one of the joints in your pipe. Water is relentless, and it could take months or a year to work it's way down the pipe. If it finds a way through the first barrier, it will just keep on going.
    Eddie
  3. #3
    Join Date
    Mar 2013
    Posts
    132
    Summit, NY
    JCB MIDI CX
    so you are suggesting that I pour a bag of cement at one of the Pipe Couplers as I backfill ?
    JCB MIDI CX :
    4:1Bucket
    Cub Cadet :
    42" snowplow
Similar Threads
  1. Using a Well to Feed New Pond/Lining Pond
    By MOZSVATH in forum Projects
    Last Post: 11-22-2012, 07:16 PM
  2. Gravity feed vs mechanical feed wood chipper
    By bikerdib in forum Kubota Owning/Operating
    Last Post: 07-29-2012, 11:45 PM
  3. Pressure washer with a gravity feed???
    By mx125 in forum Owning/Operating
    Last Post: 05-26-2007, 10:54 PM
  4. Water tank gravity feed: how and what
    By beowulf in forum Projects
    Last Post: 05-30-2006, 02:52 AM
  5. Watering lawn from Pond - what is needed
    By Larry_Van_Horn in forum Related Topics
    Last Post: 04-21-2004, 11:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
