Shooting Bench
   / Shooting Bench #1
jbbankshot
Member
John Deere 3320
Here is my shooting bench project. I modified some simple plans I found on the internet. I made it 48" wide vs 36" and I made it three legged vs 5 legs.
   / Shooting Bench #2
Nice job, I found those plans as well. I like the changes that you made.
   / Shooting Bench #3
I agree, nice job! If you don't mind, can you post the plans so I can see the exact measurements.
   / Shooting Bench #5
Do you have a router?.. I would take my router and a roundover bit, and hit all of the edges with it. It would just take a few minutes, and it would make all of the surfaces your body would contact just that much more comfortable.:) Great build.
   / Shooting Bench #7
Nice work! Great call on 3 legs instead of 5. 3 legs dont' wobble.
   / Shooting Bench
I do plan on rounding the edges, I figured I'd use it a few times first. The three legs does stop the wobble, but when you sit on it or move your body position, it's not quite as stable as having the extra seat supports. I will need to move the bench as crops change, because that dictates my shooting angles.
I'm trying to figure out the best way to catch brass. None of my prebuild ideas will work because the brass ejects at an angle back than I anticipated. So, I will need to do some trial and error with a cardboard box.
   / Shooting Bench #9
I have always just stretched out a tarp, and weighted it down with rocks on 4 corners.. It is awfully hard to tune ejectors to always flip them in a reasonable sized box.:)
   / Shooting Bench #10
Awesome...Thanks for the plans.
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53472)
2015 Ford F550...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2013 JOHN DEERE 470G LC EXCAVATOR (A51246)
2013 JOHN DEERE...
UNUSED RAYTREE REDM32-32" EXCAVATOR DRUM MULCHER (A51248)
UNUSED RAYTREE...
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
