mikehaugen
Elite Member
So my boy (3 years old) is very fascinated with trains. I am planning a train themed bed to build and I have most of the plan done but for the "boiler" part I want some curved plywood. I am thinking the ends will be semi-circle plywood pieces and I want to bend another piece of plywood over the semi-circles. It will be 30" long and 20" radius. It's going to be painted so I will just use regular pine plywood.
I know it can be done by cutting a bunch of slits in the underside of the plywood but I have never done it. I think 1/2" plywood, but how deep should I make the grooves? I could technically figure the distance between the grooves by calculating the differences between the two circumferences and dividing by the saw kerf thickness, but I know stuff like that never comes out perfect. I would rather have more grooves to make it easier to bend and I don't care if the grooves close up completely underneath.
Any suggestions as far as groove depth or spacing? Is 1/2" a good thickness? Any particular grade of plywood more suitable for this? With a 30" length, are just 2 ends sufficient, or should I make an extra center piece?
Thanks in advance for any help.
