Jpcjguy
Hi all,
So I am looking to level out my backyard a bit. It is a 2 acre property and I would build a retaining wall where I am cutting into the ground. Here is an aerial view:
Section A is where I will be taking the dirt and moving it section B. I also want to level out the dip in section B (arrows) The black line in section B will be a 80' 12" pipe for drainage from the tree area to the neighbors yard. BTW, I have never seen any moving water in that area - even in the heaviest rains, I think it is a "just in case". The green line that is 350' is going to be a driveway for the detached garage I am planning to locate where the shed is currently. (Shed will be moved)
Here is a side view of section B:
The red line is the slope I want to achieve - don't want a dip in the driveway to the planned garage.
Here is section A from the patio:
The red lines indicate the "cut" I want to do to get rid of the slope. I am looking at going 4-5' down.
Another angle with area in red affected:
One more angle pic:
So based on this - what kind of equipment should I use? Rent something myself? If so what type/size?
What kind of time frame should this take?
I have received some what I think is ridiculous quotes - anywhere from 15k-25k.
I also found a guy that would do it with his tractor at $85/hr. This is what he has:
His estimate was 2-3 days (only going by my pics and obviously does not account for school bus sized rocks that might be underground.)
What do you all think? First time dealing with this type of job. Oh, I am outside Richmond, VA.
Thanks!
One more angle pic:
Thanks!
