Don in LA
Member
My son has a boat slip which is in need of cleaning. We mounted a towable backhoe on a barge to dig the muck from the slip. The main problem is moving the mud from the slip to shore. Sometimes we have to go 30' to 40' feet out into the river because of the silt buildup. The muck is mostly soupy clay and sand.
We are considering buying a used grain/feed auger to move the mud after digging. The mud would be dug, placed in the auger bin and then, hopefully, pumped through the pipe encasing the auger. I believe the auger would be placed at about a 15 degree angle. From the pictures I've seen of the auger it appears to have augers that are about 3" in diameter. It was used for moving pig feed. Any opinions on weather an auger like this would work with mud?
Thanks,
Don
Thanks,
Don
