RedHawkRidge
I'm just a homeowner, but I've moved several trees. A few suggestions, probably too late to help:
- Chop these siamese twins in half. Plant each half along with the roots separately. An oak (red, white, pin, whatever) isn't supposed to have multiple stems. It isn't a birch.
- Prune the branches way back after completing the transplanting, leaving maybe 1/2 or less of the original. (As previously mentioned, the root system is approx equal to the branch system, and you've probably lost a majority of the functional roots). Cutting back the branch system is necessary even with a healthy plant.
- Backfill completely with no airpockets. Water regularly
- Even if the tree(s) live the first summer and leaf out, they will not be vigorous or show any substantive growth for 3-4 years. But if they stay alive, eventually they will regenerate their root systems, and will start a vigorous growth cycle.
I see at least two fatal problems -- you probably lost most of the tiny hairlike root fibers that perform the water pickup during the moving, rolling, etc. Second, if you didn't keep the root ball covered with moist soil during the overnight period or any other slack time, the roots surely died.
Good luck -- jim
Good luck -- jim
