Building extension for my trailer
   / Building extension for my trailer #1
travlitt
Texas
8050C Branson, Branson 2400, 8N Ford, Round Fender John Deere 110, 3 60" ZTR mowers, a bunch of ride on mowers, 8' Brush hog , 15' Bat wing
I have a 16,000 GVW bumper pull trailer that is 25'+ a 2' dove tail. When I haul my tractor and my ZTR I have a little to much toungue weight. I am building a 30" extension for it so I can move the tractor back closer to the rear end. This will move enought weight from the front of the trailer to the rear for a better load balance.
Before
My tractor with 8' brusg hog
All that is left to do is sand blast it and paint it.
   / Building extension for my trailer #2
Too bad the axles aren't forward a foot
   / Building extension for my trailer #3
IMG_1135.JPGYep, bad placement of the axles on that 25 foot trailer. They should be much farther forward for proper balancing of the load on a 25 foot trailer. They appear to be in about the same location as my 20 foot trailer so you would be putting a lot more tongue weight on it if you moved any amount forward. When I load my tractor on my 20 footer it is about the same position in relation to the trailer axles as yours but I have 5 foot less in the front..
   / Building extension for my trailer #4
That type of axle placement is usually used with a dump truck/pintel hook setup. Dump trucks can handle the tongue weight... :)
   / Building extension for my trailer #5
What kind of tow vehicle are you using.
Maybe helper springs, air bags, or a weight distribution hitch are needed on your tow vehicle.
My 22' 14K tilt bed trailer has an empty tongue weight of almost 1100# and I have no problem with too much tongue weight or rear end squat when loaded towing it with a half ton pick up. My axles are mounted back quite a ways on the trailer also.
   / Building extension for my trailer #6
It's nice to have a longer trailer. Nice fab work.
Question. Did you consider moving the axles forward?
   / Building extension for my trailer #7
I know you tried this before tackling the extension, but what happened when you backed the tractor on?
Backing it on would have solved part of the problen. When I have to have both my tractor and my ZTR for some of my mowing jobs, this is overall the best solution.
I pull it with a 3/4 ton GMC diesel and I do use a weight distribution hitch. If I can move the load toward the rear, I won't have a front end hitch weight problem.
I did consider moving the axles forward, but decided that would/might compromise the overall safety of the trailer. I needed the additional length anyway.
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
Altoz 766 Zero Turn Mower (A59814)
Altoz 766 Zero...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
