First, let me point something out. I am working on a patch of about 10 acres of hay field, so although it is not ideal to use a heavy roller due to compaction issues, it is better than the alternatives to get a smooth field so that hay can be taken off without damaging expensive equipment. Also, when I get this field done, I have another 250 acres, which about 50 of needs smoothing. I have pulled a 10ft drag over the area multiple times, and it is not the answer. Yes, it helps get the excess thatch out, and yes it helps aerate the soil, but it will not smooth the ruts, depressions and high points. Top dressing 10 acres is also not an option, at least not around here. The cost of the amount of top soil you would need is just not economically feasible. So, turf specialists Dave Minner, while I respect and agree that it is not ideal to roll a yard due to compaction, I do think it is an option for acres of hay fields. Also, after the field is rolled and smoother, I will run a core aerator over it hopefully this fall and again in the spring. To till up all these acres, destroy a good mature crop of established orchard grasses, and start over, although I originally thought was the answer, I have now concluded it is not.
So, my plan is to roll this field out so it is reasonable to mow and bale at 4-5 mph, aerate, slit seed, which will hopefully provide a hay field that will be productive. This will take substantially less time, get the field smooth, increase production, eliminate the need to destroy an existing mature stand of crop, and provide a better crop sooner.
The roller company is Grahl Manufacturing. 1-888-732-7789 Ask for Jerry. He is the owner, American made, small business owner. Very helpful. I ordered a 36” by 72” roller. They also have spiked rollers for aeration, but I prefer core aeration.
