TNGP
Member
Fall is coming and there's no better time to build a mega PTO powered incinerator to save myself a lot of pain and suffering.
Here's the idea -
48" high pitch 700rpm fan attached to the PTO via shaft and chain drive.
Wide swath vacuum collector at 72"x4".
Snail shell collector with top exhaust to keep unburnt bits low in the can.
Possible propane injection.
Now for the problems -
At zero static pressure the CFM of the fan is 43,400. The fan has a face of 1080ish square inches which makes its exhaust 51mph. For the intake if the 72"x4" is used, the intake velocity would be 190mph assuming the 43,400cfm remains constant. However, since that opening is 360 sq.in. the static pressure would be greatly increased for the fan. The problem then is the actual intake speed bottoming out and if there would be enough left to vacuum leaves, twigs and possibly grass clumps and force them into the burn chamber. To note the pitch of the fan is 38 degrees and it requires 8.5hp to turn it at 700rpm.
Here is the static pressures for the fan up to .5
@ 0.000-In. SP 43,400 CFM
@ 0.125-In. SP 41,957 CFM
@ 0.250-In. SP 40,294 CFM
@ 0.375-In. SP 38,364 CFM
@ 0.500-In. SP 36,102 CFM
My calculations bring the SP to about 9.5ish if sucked through a 360 sq.in. opening, but I have no idea if thats right. If anyone reading this knows about this, PLEASE let me know.
As for the propane, I don't want t turn the burn chamber into a giant shrapnel producing death trap, but I do want to keep it close to 1,800F to burn up the twigs and not produce any smoke.
Give me your opinions...
Here's the idea -
