WoodChuckDad
Elite Member
- Joined
- Jul 15, 2015
- Messages
- 2,714
- Location
- Free Union, VA
- Tractor
- Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
I have searched the old forums and only been able to find one thread on a retaining wall made from stacked cement bags. It isn't anything revolutionary, but it is something that I have not done before. I am creating a bridge crossing over the dam overflow of my pond. I hired an engineer to speck out the pipe needed and he gave plans for the bridge as far as the pipe needed and the grade but the retaining wall is up to me. The plans call for two 48 inch pipes, 60 feet long put in at a slope that takes the exit end10 feet below the entry end. At first I was going to use a precast headwall but the cost delivered will top $10,000. Also it would weigh around 6,000 lbs so maneuvering it into place would also be a challenge. Instead, I am going to use stacked 80 lb backs of quicker, pinned together with Rebar. I will come up 2feet above the pipe so total height will be 6 1/2 feet. I have ordered 400 bags of concrete to be delivered on the same day the pipes are to be delivered. I have seen a few threads about building retaining walls so I assume following the same principles would make sense. Should I put 1 inch gravel between the wall and and back fill? and if so, how much and how high?
