Beltzington
Looking for a durable less expensive solution for B&B siding than using all wood. I have never worked with cement siding but was considering using the Hardie planks mounted vertically for the board and using cedar for the battens. The plank is spec'd at .312" thick which I am sure has allot of flex but I will be nailing it flat onto 1/2" sheathing so I do not think this will be an issue. I know they make a Hardie Panel but I do not want any horizontal seems showing. My main concern is the lap siding is tapered across the width. Any other problems I am overlooking?
