radioman
Super Member
looks like you are between a rock and a hard place. your original intentions was to convert your pole barn living area into a workshop after house is built, but now you want to stay in it. I am going to assume big on something -- you already built the interior walls for the living space so your have no idea whats really happening inside the walls.
If my assumptions is correct ( i know my bad to assume but ..) I think your best plan of attack now is to remove the one window area whewre exterior metal siding under the window and above. its only screws. I am pretty sure it will tear your foam insulation - but i am pretty sure that you will find your answers there . is the foam eaten up by mice? poorly applied? missed spots? soaked with water? need better rubber membrane tape applied around your windows? is the foam deteriorated along on the bottom where ribs stick out from snow melting absorbed into the foam where its missing a bottom cap and caulked?
This would be my plan of attack as an internet answer .. If I was there in person - it might be a different plan of attack - i dont know since I feel there its easier to determine the issue in person.
