ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,499
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Use the blade with tail wheel, not the box blade. Too hard to control the box blade. Blade with tail wheel will be very easy to control. Make half a dozen passes driving in the existing tracks. Center hump will disappear. Repetition is your friend. You don't want to cut the center hump loose in one pass. Too much material to deal with. Repetition.
Then when done, drive on it for a couple weeks and see where you end up.
