sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,212
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
The reason your seed did not germinate is more likely poor soil-to-seed contact than lack of rainfall. If the ground is hard packed, the seed will lay on the surface and not be able to form roots as it germinates. It would be best if you could find some way to break the ground. A simple 8' set of old Dearborn or Pittsburgh cultivators with pointed teeth will do a great job. Break the ground up and broadcast the seed and don't worry if it isn't real smooth. Rainfall will take care of that and the first rain will bury the seed enough for germination purposes. I have done many acres like this.
Something else to consider would be the addition of a "nurse" crop such as oats (an annual) that is broadcast at the same time as your seed and provides shelter for your emerging seed. That works here but ask your extension agent. Also, you should add some fertilizer to help the roots form. Any equal number "balanced" fertilizer like 19-19-19 would be perfect and I'm thinking 250-300lbs per acre put down just before or just after cultivating.
There could be some fine tuning of this based on nuances of your area and who is telling the tale but this is the low-buck way that works for me. I do a lot of fancy work as well as a fair amount of low-buck work like this and it's not hard once people grasp the need for good soil to seed contact. Rainfall will take care of itself. Failure to understand seed to soil and grass will never happen.
