kevin37b
Forget the fabric . Put2" down and let it work in for a year . If you have spots that pump , dig out the mud and fill it with 2 " . As said do not drive in the same tracks every time you use it . Looks to me like it will drain fine . Get the rock worked in and stabilized and give it a layer of asphalt millings if you can find it . The problem with fabric is that is never installed correctly . The wind blows and it wrinkles or bubbles and the first time you drag it , you rip it . You may be more deliberate in your case , just is not worth it . I do not see any problem with what you have done . Remember one thing , we spend a lot of money repairing paved highways .Trying to help , Kevin .BTW you did 1 **** of a job with that dozer .
