Pushing back the woods
   / Pushing back the woods #11
I have a DR brush mower,,,go with the brush hog. Dr works fine but only has a 26" blade, so takes lots of time and Blackberry bushes like to grab your arms and face if you aren't careful.
The only reason I use it is I don't have a tractor yet. I think you can buy one heck of a brush hog for $2,000, which is what the 10.5 DR costs.
   / Pushing back the woods #12
rwarner
This is the BEST thing I have found for removing saplings up to about 4 inches. It gets the tree, root and all and there's less ground disturbance then pushing the trees over and "flipping" them out of the hole with the FEL.
I built this one myself to mount on the 3pt (added the rest of the "fingers" just this week) but it's based on the Brush Brute. I think the Brush Brute mounts on the FEL but you have to remove the bucket to mount it.
   / Pushing back the woods #13
Now I wonder how hard it would be to adapt that for pulling T-Posts? Or do you think it would 'grab' a t-post as is, and pull it w/o bending it? Maybe adding a flip across bar to lock onto the nubs of the t-post?
<P ID="edit"><FONT SIZE=-1>Edited by scruffy on 04/09/01 00:10 AM (server time).</FONT></P>
   / Pushing back the woods #14
scruffy
I hadn't thought about the Tposts, but I have some that have to go and I'll try pulling them with this rig and let you know how it works.
   / Pushing back the woods #15
FANTASTIC!! Looks GREAT! I'm gunna fire up the welder this weekend!
Thanks for the idea!
Steve
   / Pushing back the woods #16
Ditto that!!! How long did you make the teeth and what are the gaps at the open ends???
Thanks in advance
Gordon
   / Pushing back the woods #17
TraderMark, how long are the fingers, spacing, and how are they made... Thanks, I will have a local shop get started this week...
   / Pushing back the woods #18
I'll do my best to give all the specs on the first try, but if I don't.... just holler !! /w3tcompact/icons/laugh.gif
The crossbar and the upright for the top link are made from 2X3X1/2 wall tubing.
The fingers are 15 inches total length (that leaves 12 inches protruding from the crossbar) and are made of 1/2X3 flatbar.
I left 1/2 inch in the center of each finger and tapered them back 11 inches. Each finger has a piece of 3/8X2 flatbar welded edge ways and welded to the crossbar to prevent the fingers from bending.
   / Pushing back the woods #19
This might be a really dumb question but... have any of you guys that cut these 1-3" dia. saplings ever punctured or cut a tire by driving over the stems in future passes or while mowing a month or three later? I would think they would be pretty rigid already when they are that big... or doesn't it leave the stems very sharp when they are cut off? Those tires are expensive! /w3tcompact/icons/shocked.gif I may be faced with this situation in the future & would hate to be faced with big tire repair bills.
Troy
   / Pushing back the woods #20
<font color=blue>have any of you guys that cut these 1-3" dia. saplings ever punctured or cut a tire by driving over the stems in future passes or while mowing a month or three later?</font color=blue>
No, I haven't, but my neighbor sure did; on a tractor with 38" wheels and I helped him fix the flat; not a lot of fun, especially since he didn't know until he did it that his tires were filled with calcium.
Bird
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2012 Ford F250 (A55973)
2012 Ford F250...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A57880)
2014 PETERBILT 384...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A55315)
Magnolia Trailer...
