EddieWalker
Epic Contributor
Keep an eye out for heat stroke symptoms.
Symptoms of Heat Stroke
The hallmark symptom of heat stroke is a core body temperature above 104 degrees Fahrenheit. But fainting may be the first sign.
Other symptoms may include:
Throbbing headache
Dizziness and light-headedness
Lack of sweating despite the heat
Red, hot, and dry skin
Muscle weakness or cramps
Nausea and vomiting
Rapid heartbeat, which may be either strong or weak
Rapid, shallow breathing
Behavioral changes such as confusion, disorientation, or staggering
Seizures
Unconsciousness
The only symptom that I've noticed is the confusion. I'll forget what I'm doing, or why I'm standing there. Sadly, this also happens first thing in the morning, or in the middle of winter when heat is not a concern. But it is the first sign when it's hot out that I notice, and it's when I start planning on calling it a day.
A few years ago my dad was helping me remove the engine from the dump truck. He was using the impact wrench to take off the bumper. It was in the mid 90's with high humidity, which is normal for our summers. He kept telling me that every bolt was stripped and that we had to cut them all off. I think he tried a dozen bolts with the same results. I thought that was odd for every single one of them to be stripped, so I took a look and instantly realized that he was using a socket that was several sizes to big for the bolts. He was too hot and not thinking clearly, or able to realize that the socket was too big. I sent him inside to the AC.
