Page 3 of 7 FirstFirst 123456 ... LastLast
Results 21 to 30 of 70
  1. #21
    Join Date
    Jun 2017
    Posts
    92
    Hillsborough, NC
    Yanmar 424
    Default Re: DEMOLITION -- Am I CRAZY to do this??
    Quote Originally Posted by two_bit_score View Post
    Probably going to be more work than it seems it would be to demo it. I tore down an old mobile home over a year ago and that thing was a real job.
    I think getting it on the ground on its side would be best. Then take a sawsall or chain saw and cut it up. Use pallet forks to load it directly into a trailer to haul it off.
    TBS
    Agreed.
  2. #22
    Join Date
    Jun 2017
    Posts
    92
    Hillsborough, NC
    Yanmar 424
    Quote Originally Posted by Egon View Post
    Put a cable around it as high as you can get it & then drive away with the cable hooked to the tractor. Once on the ground break it up with the loader.
    This is essentially what I think I should do, thanks
  3. #23
    Super Member two_bit_score's Avatar
    Join Date
    Dec 2008
    Posts
    9,808
    Texas - from the brush and pear to the piney woods
    John Deere 110 TLB
    Quote Originally Posted by VeRV77 View Post
    I have a piece of property I'm cleaning up and it has an old freestanding shed that needs demolishing (see photo). The lower joists and vertical members have rot, and it looks as if it could fall any moment.
    How do I do this without killing myself?? Cutting or knocking out any structural members while standing anywhere near the shed seems like a REALLY bad idea. Use of fire is out of the question. A local contractor wanted thousands to do the demo for me, so I'm not going that route either.
    MY PLAN SO FAR: Loop a cable through the vertical studs on one side of the shed, near ground level. Run cable through a heavy-duty pulley that is strapped to a large adjacent tree (maybe 20-30 feet away). Attach other end of cable to my tractor and slowly drive forward. The idea is that if the cable snaps from its attachment (either on the tractor or, more likely, on the shed), it will fly toward the pulley/tree and not toward the back of my head. If half the shed is still standing, repeat process on other side. Once it's fully collapsed, Sawzall and sledgehammer for the rest.
    I'm not sure how thick a cable I need, but I know I want a significant safety factor. Not even sure this is a good idea. Anybody have any experience with this? Suggestions appreciated.
    Attachment 519797
    Do you have a winch?
    Chain saw would be quicker than a sawsall if you can avoid nails.
    Pulling it over might help break it up a little
    Pallet forks to load it in as big pieces as possible.
    TBS
  4. #24
    Join Date
    Jun 2017
    Posts
    92
    Hillsborough, NC
    Yanmar 424
    I don't have a winch. I was actually considering putting one on the front of my tractor for the sort of thing. Never owned a winch before though, not much experience with one.
  5. #25
    Join Date
    Dec 2008
    Posts
    9,808
    John Deere 110 TLB
    Good opportunity to get a good one and put it on your truck. That tree to the right in the picture would be a good point to pull the building over if you got the chain up high.
    TBS
  6. #26
    Elite Member Sawyer Rob's Avatar
    Join Date
    Dec 2014
    Posts
    2,835
    Upper Mid West
    several brands
    I've demoed small bld's like that, mobile home too... Pallet forks with a grapple is your friend!
    I stab the forks right through the wall, forks aimed up, grapple the piece on the forks and rip it right out! driving over to where you want to dump the piece.
    It doesn't take long for me to take the whole bld down... IF it falls over, all the better to grapple loads and drive away with them.
    SR
  7. #27
    Join Date
    Dec 2013
    Posts
    1,809
    Southern Alberta, Canada
    4410 and F-935 John Deere, MF 245
    If this shed was at my place I would just lift it up on one end and slide the flat deck under. Then I would go to the other end and lift it with the loader and slide it on the trailer. Then off to the neighbours burn hole and push it off into the hole. Done!
    It looks like you won't have it quite that easy. Be careful!
  8. #28
    Join Date
    Oct 2011
    Posts
    2,077
    Olalla WA, Kitsap Peninsula, West of Seattle
    Kubota BX25
    Not familiar with your tractor size; your pickup may be a better prime mover. I have been involved in a number of demo projects like yours, some bigger. Usually used a tracked unit with 4-1 bucket and crunched it up and loaded in a container. You only need to take siding off on the two sides parallel to the pull direction. Chain saw definitely the tool to use; have a couple spare chains. Small saw will keep chain cost down if you ruin one or more. If I still had my Dodge 1 ton I would get on the side and try to push it over; at least it would determine the structural strength. As recommended before get your cable up high and let the leverage assist.
    LOL, Ron
  9. #29
    Join Date
    May 2008
    Posts
    1,619
    Prince Edward Island, Canada
    Kioti DK45SC
    Years ago, I had a dilapidated 20' x 40' barn that I managed to collapse by pushing on one corner (diagonally) with my Kioti DK45. The cleanup was a LOT more work than the original demolition. That spot is now my vegetable garden and I am still finding pieces of broken glass, nails and miscellaneous other rusty metal bits. It makes gardening a bit like an archaelogical dig.
  10. #30
    Veteran Member check's Avatar
    Join Date
    Sep 2008
    Posts
    1,899
    Toronto, Ontario, Canada
    2009 Kubota BX25
    Default
    How much clearance do you have on the right-hand side? Seems to me it would be a piece a cake to just hook a chain over the top plate in about the middle, and then pull it over with a truck or your tractor.
Similar Threads
  1. House demolition
    By Loadstar in forum Projects
    Last Post: 11-20-2015, 08:55 AM
  2. House demolition
    By Foozle in forum Projects
    Last Post: 03-19-2015, 02:34 PM
  3. demolition hammer
    By swick1 in forum Build-It Yourself
    Last Post: 12-07-2011, 09:02 PM
  4. demolition
    By yellowdogsvc in forum Welding
    Last Post: 10-21-2011, 09:54 AM
  5. Bridge Demolition?
    By micromike in forum Projects
    Last Post: 08-23-2003, 09:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
