Hi TBN!
I admittedly did not know a lot about building a road when I started clearing and getting ready for the shop build a long time ago. So now that we actually have the house built (for about a year now) I was hoping to get it in a lot better shape for the winter. The driveway (road) is about 1800' long in total. The first section has pretty large rock on it with fines that has held up pretty well but there were some problem spots where water was running down the middle (because I was a newbie) on the second section so I created drainage on the sides and a few small trenches cutting across the driveway to divert it to those trenches where necessary. I should mention that some of this driveway is running uphill/downhill so the water can really gain some speed. I also had water ponding in front of my shop and no driveway yet running from the shop to the basement garage. So I dug out (also expanding) all of the area in front of the garage to get it graded so that it would better drain the proper direction away from the driveway. This got rid of the ponding issue. I then had 3 truck loads of 1.5" crusher run brought out. Two of these were spread on the second section to the shop, the third stockpiled. After boxblading the two spread loads that section of driveway is working pretty well. I have to do just a bit more to it but is way better than it used to be.
So here is the issue and where I need some experience. I spread the third load on the area in front of the shop and around to the basement garage. Graded it all with the box blade and compacted it with my bobcat (also compacted the dirt underneath with my bobcat the best I could). Looked great! I noticed immediately after it got some moisture in it that when driving on it cars just SINK IN. I mean bad. Like nearly getting stuck in it. I am feeling a bit defeated at this point but I really need to get it fixed before winter gets any closer and sets in. Here are some options I am thinking of.
- Get much larger rock (maybe 2.5"-3"?) and spread it all across this area and compact, wait til spring and put the crusher run down if needed
- Get driveway fabric and put down then rock
- Concrete the whole area (not the whole driveway), I want this eventually but not sure I can afford it before winter
- Asphalt the whole area (should be lower cost than concrete but got an estimate on the entire driveway of $42k!)
Any other thoughts are welcome. Our dirt area in the back of the house is all muddy all the time too, very frustrating. I am thinking that may be because of our high clay content in the middle TN area. Not sure if I sow some good grass out there in spring if it will tie it all together or if I need to get top soil first.
Attached a picture. The driveway over to the basement garage goes off to the right but it did not have gravel on it yet.
Thanks as always,
Nick
