Page 5 of 5 FirstFirst ... 2345
Results 41 to 47 of 47
  1. #41
    Veteran Member FTG-05's Avatar
    Join Date
    Jan 2011
    Posts
    1,551
    TN
    Kubota L4330 w/FEL, Kubota RTV900, Kubota ZD326S
    Default Re: How much does a load of fill dirt cost typically?
    Quote Originally Posted by FrankRetired View Post
    Re; Dumping on a side hill.
    Your quite right, I just retired from 14 years in a dump truck and there would be no way that I would raise a box on anything but reasonbly level gound, especially with dirt. Dirt can be a little sticky especially when it is moist. In the yearIs I worked I never laid a truck or trailer on its side but three of my coworkers did and I've seen a few pup trailers on their side too.
    If it's wet dumping down hill it can be problem driving an empty truck up grade without gravel. It always worked best backing up an upgrade as far as I could and then dumping. Pulling an empty truck and trailer downhill usually worked quite well, even when the site was greasy wet.
    My employer charged by the hour if a truck got stuck, and charged for the tow also.
    I'll have to show pics of the 2 areas I plan to put my pistol range and see what you guys think - especially you since you have experience dumping dirt. I suspect Location #1 (Poplar grove) will be a No Go; but it will be interesting to get your opinion.
    The person I'll be buying the dirt from is a one man operation and I'd hate to put him out of business, if only for a couple hours while we try to find a tow company willing to retrieve his truck. Not only does the side hill/Poplar grove pose a problem for the dump truck, but also the tow truck.
    Still too wet to take pics. Stay tuned!
  2. #42
    Join Date
    Jan 2011
    Posts
    1,551
    TN
    Quote Originally Posted by JerryK View Post
    Here is a picture of my 50 yard pistol range with berms at 10,25, and a trench berm at 50 yds. [ the berms are actually a yard or two past the 10,25,50, with the target shepards hooks about at the right distance... ] It is built kind of on a side hill shooting down some. I could have put it shooting into the hill, but that would be towards my house/barn and the gravel road. This is pointed out back into the hardwoods.... I have changed it some since 2014, and it needs work since a big beech fell near it about a month ago. With another dead beech I need to take down for safety reasons [ beeches are falling like flies up here from the beetles/fungus ]... I have a shooting table on the rise that has a treated wood structure on the right to hold a catch tarp for the brass out of my Glock 17. Have run thousands of rounds thru it shooting at the AR500 targets... Cheap entertainment...
    PS: Just bought me an 18" AR500 gong on Amazon. Going to extend my in ground trench/berm out some this Spring so I can do the 80 yard gong thing like my hero Hickok45... don't think I will be trying any gong pistol shooting out at 230 yards like he does, though... Life is GOOD
    Thanks for posting the pics!
    We should turn this thread into a "Show Your Pistol Range" pic thread. Whattya think???
  3. #43
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,680
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST
    Quote Originally Posted by FTG-05 View Post
    OK with me, but mine is not that big. We have guys up here that have underground pistol ranges that they can use year round. No mosquitoes/gnats/etc....
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
  4. #44
    Member FrankRetired's Avatar
    Join Date
    Aug 2017
    Posts
    40
    Lyman, WA
    Ford 1715
    If there is a construction nearby, most contractors are happy to give away you haul dirt. Many times the contractors we worked with made arrangements with a homeowner or farmer and we would haul the dirt to their designated dump site. I don't know how the payments were arranged, but we were just getting truck time for the job. The contractor was avoiding paying a dump fee, (about $5 a yard) at a county approved fill site, and paying less truck time since his arranged site was usually considerably closer to his job. We did this for anything from two or three loads to thousands of yards. If homeowners called our dispatch we would haul the dirt to them for a nominal fee, (probably that same $5 a yard) and charge the contractor hourly truck time with no dump fee. Ask around and you may find your dirt, dirt cheap. Just wait for a week or two of dry weather to start your project.
    Experience: that most brutal of teachers. But you learn, my God do you learn. C. S. Lewis
  5. #45
    Super Member dragoneggs's Avatar
    Join Date
    Jun 2013
    Posts
    8,022
    Seabeck, Washington
    Kubota BX-25D, Z122RKW-42, and JD LTR166 Lawn Tractor
    I know this might not help but I have been on the giving and receiving end of 100s of yards of free fill. First, when I put in a sports court on my previous property and I had about 400 yards moved out to create a flat sunken area for a 30 by 60ft concrete pad. I put a sign out on the road... free fill you haul. Within a day I had someone arrange to haul all I wanted. Recently, my neighbor put in a huge retaining wall and I got hundreds of yards free delivered because I was next door and it saved him money... I didn't even need to load/haul it, he just travelled a few hundred feet with a decent sized loader. I guess what I am saying, is to advertise your need and maybe you will get lucky with a close by neighbor. Here is my before/after fill... I added a drive around my greenhouse after giving so much away twenty years ago.
    How much does a load of fill dirt cost typically?-img_5947-jpg How much does a load of fill dirt cost typically?-img_0177-jpg
  6. #46
    Join Date
    Oct 2010
    Posts
    225
    Santa Cruz, Ca
    BCS735/720 Ford1200
    I've received lots of free dirt but I've been turned down probably better that 10 to 1 because I was to far away. The free dirt with free delivery always goes to the person who is closest and has the easy room for the trucks to come in, dump and pull out quickly. Usually CL is good for me, but I've stopped by construction sites when out and about when I see trucks being loaded and ask if they need a place to dump. Sometimes you get lucky.
  7. #47
    Join Date
    Feb 2004
    Posts
    2,680
    Be careful when trolling for free dirt. Make sure they understand you want dirt only, no concrete. Some folks will take advantage of you... even dump construction debris mixed in with the ' dirt '...
Similar Threads
  1. fill dirt questions
    By heppeone in forum Projects
    Last Post: 11-01-2014, 01:13 PM
  2. fill dirt and surface preparation
    By Anonymous Poster in forum Rural Living
    Last Post: 08-18-2014, 12:51 AM
  3. Fill dirt?
    By RadarTech in forum Projects
    Last Post: 03-25-2008, 08:03 AM
  4. SOURCES FOR FREE FILL DIRT
    By LBrown59 in forum Owning/Operating
    Last Post: 04-07-2006, 08:29 PM
  5. Neighbor fill dirt delima
    By DCRC in forum Rural Living
    Last Post: 01-06-2006, 09:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
