square1
Jet pumps use water from the pond / lake as the sourceThanks for all the suggestions...my only water supply is my well....
Another idea that I've had with a pond was to build the pier on posts and the deck on floats. Add a roof to the deck area and make it detachable, then with a small outboard motor, I could have a floating island. I'm leaning towards an electric motor with a solar cell to keep the battery charged. It's all just wild daydreaming, but it's also something that I think I would really enjoy.
That's my plan at the recently purchased property. This 34' 7" long section will be anchored on the land end and extend 20' out over the water to a floating dock that will be removed in winter using the pontoon trailer.If it is only 16 why not cantilever it out over the water? I had an engineer design a cantilever snore mounted dock that would extend 30 in the water. I didn稚 end up building it I bought a floating aluminum one but it isn稚 that complicated to build with a lot of concrete and some I beams.
