Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Veteran Member FTG-05's Avatar
    Join Date
    Jan 2011
    Posts
    1,551
    TN
    Kubota L4330 w/FEL, Kubota RTV900, Kubota ZD326S
    Default Re: Request for beam calculation, please.
    Quote Originally Posted by countrybumpkin View Post
    Is something like this what your trying to accomplish ? Attachment 539832
    Yep exactly. Except homemade.
    Not as HD and certainly not as expensive! $1200!!! Ouch!
    Also does not have to have adjustable width.
    And now I know what they are called: Lawn Mower Adapters.
    Thanks!
    ETA: And it's from the same people that made my lift: Atlas. here's my lift: Atlas(R) PV-12P Overhead 12, lbs. capacity Adjustable Height 2 Post Car Lift (EXTRA WIDE/EXTRA TALL) | GSES
  2. #12
    Join Date
    Jan 2011
    Posts
    1,551
    TN
    Quote Originally Posted by Rock Crawler View Post
    Why would you even consider a 1000 lb load on such a tiny member? 2x2x0.25 would be something to consider and it's still dirt cheap. 4x4x0.25 would be much better if you want a human under that load.
    Ability to drive over it. Obviously it's going to have to be something heavier duty.
  3. #13
    Join Date
    Jan 2011
    Posts
    1,551
    TN
    Maybe I need to think orthogonally:
  4. #14
    Veteran Member countrybumpkin's Avatar
    Join Date
    Jun 2005
    Posts
    2,263
    Southeast Missouri
    Kubota L3410; Kioti NX5510C
    Yep, Iíve too thought about building one also, I had seen that style also hen I was looking for the pic I posted.
    If your going to be a Bear, Be a Grizzly!
  5. #15
    Join Date
    Jan 2011
    Posts
    1,551
    TN
    Yep, I’ve too thought about building one also, I had seen that style also hen I was looking for the pic I posted.
    Plus the advantage of the type on my post #13 is that it would also be useful for small car that sometimes a pain to find a hard point. Use that platform cover a good part of it with that 3/4" hard rubber mat from Tractor Supply (horse stall mat) and lift away. Another advantage is that the structure is oriented front-back vs. side-to-side, so it won't interfere with anything in the center of the vehicle.
  6. #16
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,759
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Without doing any calcs, I wouldn't even attempt to lift my lawnmower with a 1x1 square beam as configured.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
Similar Threads
  1. Calculation help
    By Mysfyt in forum Build-It Yourself
    Last Post: 12-01-2015, 01:35 PM
  2. Receiver drop calculation
    By Eric_Phillips in forum Trailers & Transportation
    Last Post: 06-22-2014, 06:44 PM
  3. Box-beam or I-beam question
    By Aussiebushman in forum Build-It Yourself
    Last Post: 11-03-2010, 07:59 PM
  4. Log Splitter - I beam or box beam
    By Anonymous Poster in forum Build-It Yourself
    Last Post: 03-03-2003, 11:11 PM
  5. concrete yardage calculation
    By RobertN in forum Projects
    Last Post: 05-20-2002, 09:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
