Page 2 of 10 FirstFirst 12345 ... LastLast
Results 11 to 20 of 97
  1. #11
    Join Date
    Oct 2014
    Posts
    869
    San Diego, Tx
    New Holland TC40 DA, John Deere 17D mini-ex, Hyster SX50 forklift
    Default Re: Pole Barn VS Red Steel building - Need some more advice
    You can build a 3,000 sq/ft metal building with 2 guys and limited knowledge. I built a 2,000 sq/ft mostly by myself. I hired the slab and the roof, erected almost all of the framing alone and my wife helped me with the walls.
    Completely finished, $60,000 will be tight for 3,000 sq/ft. I'm about $40-$45 into mine now and still have a fair amount of interior work and the septic to do before it's what I'd call done done. It's far enough that I can work in it though, so our house additions have taken higher priority. I overbuilt my slab, I could have saved about $5,000 there but, you'll eat that up with the extra square footage.
    I had a lengthy thread about my build, from dirt work to where I am now. I made some mistakes along the way, which I openly admitted, if you think you might want to give it a go, look over that post, it includes all the things I wish I'd known when I started.
  2. #12
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    19,380
    Tyler, Texas
    Several, all used and abused.
    Local costs usually have a lot to do with politics, code and labor. There isn't much you can do about those things, it is what it is. As for design, a rectangle is going to be the most cost effective. Then the width of your span. Metal has a huge advantage when going for a wider building with a larger span. Wood trusses have a limit where they are cost effective. Metal will require concrete and massive footings to support the load on a small point.
    Cheapest building is a wood post pole barn. Concrete and labor never come down in cost, so you should always do it now.
    Since you mentioned not wanting a normal looking barn and you are wanting something unique, consider what you will use on your walls. If you are going to side them, then it might be cheaper to go with stick framing. If you are going to pour concrete anyway, then stick framing makes more sense. Instead of thinking barn building, look at it as framing a house without any interior walls.
    I personally like big Pressure Treated 6x6's in the ground with concrete around them for the floor, and a footing along the perimeter for stick framing the walls with 2x6's vertically. This allows me to put on Hardie lap siding on the exterior, insulate with fiberglass batts if I want to, and osb on the interior walls. The 6x6's add enormous strength to the walls for longer distances, and the sheething on the exterior and interior will totally eliminate any racking on taller walls. Then you add your trusses to the tops of the walls at the posts. If at a later day you want more square footage, it's super easy to add on to the side walls with a lean to type space.
  3. #13
    Join Date
    Jan 2015
    Posts
    2,127
    Northeast & FL
    Ford 1920 4x4 FEL, Ford 3400TLB, Ford 8N
    Quote Originally Posted by EddieWalker View Post
    36' x 48' x 14' + 2 big doors, Morton building (unfinished inside) with 5" concrete floor, cost me just under 12K, 34 years ago.
    I wonder what that would cost now?
  4. #14
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    3,506
    central Iowa
    JD 2720
    Quote Originally Posted by 747driver View Post
    Thanks ! I grew up in the Midwest so I knew about Morton and their quality. If you watch their construction YouTube videos you will see how they put the small things in place that leads the industry. They will build anything you design for them....for a price !! The building will be put up in June...I have to wait my turn.
    Spend enough and they may give you a free sign.
    Pole Barn VS Red Steel building - Need some more advice-morton-sign-jpg
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  5. #15
    Veteran Member repowell's Avatar
    Join Date
    Jan 2011
    Posts
    1,296
    East Texas
    NH Boomer 8N, NH TC40DA
    I like my Morton sign. It was a little pricey. But if you buy the sign they will through in a pretty nice building and a jacket.
    In all seriousness, Morton does built a high quality building. For us it was well worth the price.
    Pole Barn VS Red Steel building - Need some more advice-100_0657-jpg Pole Barn VS Red Steel building - Need some more advice-morton-jacket-jpg
    Randy
    NH Boomer 8N, 6' Bush Hog Squealer Rotary Cutter
    NH TC40DA, 16LA FEL, Red Master II Harrow
    Land Pride 6' Tiller, 7' Landscape Rake
    2017 GMC 2500HD 4X4 6.6 Duramax, Allison
    2008 GMC 2500HD 4X4 6.6 Duramax, Allison
    Big Tex 12GP 20' GN trailer, 50LA 14' bumper pull
    Kawasaki Mule 4010 Trans4X4, Kubota ZD1211 60"
  6. #16
    Join Date
    Apr 2015
    Posts
    124
    Colorado
    LS G3038
    I did a 30x54x12 red iron type steel building and it was under 12K delivered. I put it on my existing concrete pad and had it erected for 9K. So far i'm 22K into this after the electrician came over.
  7. #17
    Join Date
    Apr 2015
    Posts
    124
    Colorado
    LS G3038
    Quote Originally Posted by repowell View Post
    Good looking barn! My wife would love to have something like that.
  8. #18
    Join Date
    Jan 2015
    Posts
    2,127
    Northeast & FL
    34 years ago I got the sign, but no shirt.
    Maybe I should complain?
    Your building looks GREAT !!
  9. #19
    Join Date
    Jan 2011
    Posts
    1,296
    East Texas
    Quote Originally Posted by sw99 View Post
    Thanks. Just say the 2 words that make a marriage work, "Yes dear".
    Randy
  10. #20
    Veteran Member Peter 315's Avatar
    Join Date
    Mar 2016
    Posts
    1,429
    NH
    Kubota L3800 hst Kubota l47 tlb ( John Deere 770 sold )
    Nice barn what size and how many stalls ?
Similar Threads
  1. Replies: 7
    Last Post: 08-14-2017, 09:44 AM
  2. Pole barn vs. Steel Building
    By hokiebird in forum Projects
    Last Post: 11-28-2016, 01:13 PM
  3. Pole Barn vs Steel building ASAP!!!!!
    By 46ford in forum Projects
    Last Post: 04-08-2013, 11:54 PM
  4. pole barn/steel building, woman cave
    By chevy10 in forum News/Feedback
    Last Post: 05-01-2012, 07:37 AM
  5. Barn/Pole Building Advice
    By SOS in forum Projects
    Last Post: 04-19-2007, 06:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
