Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,197
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
I'm cutting in a roadway to access a little level spot on some steep land.
The access turns off my driveway above.
I want to park a vehicle on the level spot (under a small roof).
I'm first cutting in a preliminary road to the level spot, and will level it out first.
I plan to dump concrete rubble down from the driveway above. The rubble is free material, which I like.
Any comments? If the rubble ends up at a 1:2 slope is it stable to drive on without crushed rock drizzled into the voids?
And will geogrid hold the pile? I have lots of geogrid.
Do I have to use a tight weave geofabric ontop of the rubble between the topping soil and the gravel?
Lots of questions. If anyone knows of a good website, or youtube plx offer some links, or search terms.
The road is not as steep as it looks in this pic. But the sideslope is steep. What I'm trying to depict with the yellow triangle is the slope of the rubble, from the upper roadway edge to the lower shelf edge. (oops its 1:2 not 2:1)
Rubble will pile up on the preliminary road. I planned to use geogrid in layers on the prelim. road, arranging layers as it piles up.
The prelim. road is like a "support shelf' for the pile of rubble that the main access road will sit on.
Is this a good plan?
Looking from the pad back. The roadway grade down will start at the _base_ of the upper pile.
You can see the angle of repose down the bank. Thats the first 9 yds of free rubble. Free delivery too! And unlimited supply (they say).
Was thinking of building up the slope like this, except not nearly as steep, more like 1:2. Using geogrid as the pic on the right. I hope it will work as I already bought the geogrid.
