Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Join Date
    Jun 2004
    Posts
    11
    Louisiana
    Kubota B7610
    Default Creating shallow drainage ditch
    I'm a novice tractor user - trying to figure out how to cut a shallow drainage ditch with a box blade and FEL. Is there any way to angle the box blade so that only one corner digs in? This might get me started. I want a gently sloping drainage ditch that will grow grass and still allow me to mow it. Any tips? Thanks -
  2. #2
    Join Date
    Oct 2003
    Posts
    556
    wa
    bx 23
    Default Re: Creating shallow drainage ditch
    you should have an adjustment on your 3ph to set the angle for your boxblade. It may not be enough angle, depending on the depth that you want your ditch.
  3. #3
    Super Member
    Join Date
    May 2002
    Posts
    5,963
    Wylie, Texas
    JCB165HF
    You can use the loader to make a notch in the dirt. Then you can smooth out and do final grade with the box blade.
    The way I cut with the loader is to bring the level bucket six inches up from grade. Curl it down with a little pressure into the dirt. Go forward. It'll cut, without teeth too.
    Then as it gets down a bit I'll lower the bucket as I level it out.
    If you have forks for your loader you can use just one as a ripper. Then you can excavate the clods with the loader and then do final grade with the box blade.
    I've found the hardest thing to do is to remove just a couple of inches while cutting with a loader. You have to be really on top of your game.
  4. #4
    Super Member JerryG's Avatar
    Join Date
    Apr 2000
    Posts
    7,235
    Northwest Arkansas
    MF 1440-4 PowerShuttle
    Using the jack screw (side adjustment) on the three point hitch, tilt the blade to one side. With it this way, go down your purposed ditch one way and back up the other side. It will go much faster if you drop the rippers down. The first few trips, you will think that you are not getting anywhere, but have patience. It will take a while, but can be done. I have made drainage ditches 4-5 feet deep doing it this way.
  5. #5
    Join Date
    Jul 2003
    Posts
    1,168
    New Hebron, MS
    MF 1455v 4wd, 1040FEL
    Where are you in Louisiana? It sounds as though itís just as wet where you are as it is here! I used my box blade set with a ďtiltĒ to make my ditches, but when I got about 12Ē or so deep I used my FEL to move dirt quicker. At one point I used a middle-buster in the center of the ditch to get more depth, set one side of my tractor tires in the trench, and dug with the FEL. Itís easy to get the ditchbank too steep this way.
    The first two attachments show shallow swales across part of the pasture/yard to help with drainage around the house and shop.
    The next four show a ditch I dug along the property line south to north about 600 feet to drain the back corner of our 20 acres into a bayou. The pictures donít depict the ditch depth very accurately, but where it drains into the bayou I probably had to cut down five feet, and to keep a grade on the sides of the ditch where I could cut it stretched out pretty wide. Youíll be surprised how much dirt youíll pile up so plan on what youíre going to do with it!
    Attached Images Attached Images
  6. #6
    Join Date
    Jul 2003
    Posts
    1,168
    New Hebron, MS
    Pic 2
  7. #7
    Join Date
    Jul 2003
    Posts
    1,168
    New Hebron, MS
    Pic 3
  8. #8
    Join Date
    Jul 2003
    Posts
    1,168
    New Hebron, MS
    Pic 4
  9. #9
    Join Date
    Jul 2003
    Posts
    1,168
    New Hebron, MS
    Pic 5
  10. #10
    Join Date
    Jul 2003
    Posts
    1,168
    New Hebron, MS
    Pic 6
    These pictures were taken last year. Top&Tilt is a very worthwhile addition to the tractor for work like this!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
