Septic tank installation
   / Septic tank installation #1
dummy
Southern Maryland
Ford 1220, John Deere 770, Case 580E and Allmand TLB-35
There has been some discussion here about tanks so, for those that don't know how they are installed ....... for my 1500 gallon tank, first I needed a hole 7 ft. wide, 6 ft. deep, and 14 feet long. In the interest of wanting to know, I dug this with my Allmand TLB35, 12' reach and 16 inch bucket. Took almost 3 hours. Conversely, my 580E with a 24 inch bucket takes almost 2 hours for the same size hole.
Then a 6" pea gravel base was added. They back the truck up to the site and (hopefully) in goes the tank.
The tank is then checked for level, the pipes are connected (48" inlet and 51" outfall) and well, you know the rest.
   / Septic tank installation #4
Can I asked.. how much does a new tank cost? Mine's pretty old.. and seems small compared to your new one.
   / Septic tank installation #5
I was just wondering about how DEEP the tank is it appears by the 3rd pic that the tank top is almost to the top of the ground. or is that an optical thing. it looks good though...
MarkM
The 1500 gallon tank was $679.25, delivery/installation was $200.00, pipe was $253.57 (used all schedule 40 PVC) total $1132.82. Sizing is pretty much dependant on local code, number of bedrooms and square footage of dwelling.
Apparently, your eye may be better than you think. On the right side (in the pic.) we're almost 1" above grade. For the garage addition, I will be filling/resetting grade so that this same point will be ~12" below grade.
   / Septic tank installation #8
I needed a 1000 gallon tank and 8 feeder leach lines for a 3 bedroom 2.5 bath home. They also made me put curtain drains on either side of the leach field draining to daylight here in WNY. Cost installed was $4000 but was bundled up into all the excevation work by my guy during the house build
   / Septic tank installation #9
How many feet of leach lines did you guys require.And what set up do you have.Diamater pipe into junction box and how many lines of the box etc.Thanks
   / Septic tank installation #10
8 lines 50 feet long for my system. I also had what they call the infiltrator system put in for leach lines. I'll put the link here.
http://www.infiltratorsystems.com
This type of system snaps together and the ends have a cover which allows for the pipe from the d-box to fit into it.
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
ATTENTION PLEASE READ (A57148)
ATTENTION PLEASE...
500BBL WHEELED...
2022 Morbark Eeger Beever 1215 Towable Brush Chipper (A56857)
2022 Morbark Eeger...
HARDEE LR40148 LONG REACH BANK MOWER (A58374)
HARDEE LR40148...
