Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Veteran Member AndyM's Avatar
    Join Date
    Jul 2003
    Posts
    2,449
    NW PA, USA
    1948 Ford 8N and 1993 Toro WheelHorse 520H
    Default Re: How to drain out a wet field?
    Here was my project from last spring. This was the lowest spot on my property... it sloped down from the house to this spot and then back uphill again towards the road. I came up with an interesting way to fix the problem, but it has worked so far. I'll have a few puddles now after a heavy rain, but they're gone within a few hours instead of a few months.
    Drying up the front yard
  2. #12
    Join Date
    Feb 2005
    Posts
    24
    Worcester County, MA
    b7500
    OK guys, thanks for the input. I received my Howse Middlebuster today from Northern Tool. Although it seems to be a little too long, I think I can get it to work with my B7500. I'm going to make some trenches this weekend (per my diagram) and see how things drain. If it looks good and the field dries up, I can plan on widening the trenches and burying pipe this summer when everything is dry.
  3. #13
    Elite Member GerardC's Avatar
    Join Date
    Mar 2004
    Posts
    2,606
    New York
    KIOTI CK20 GEAR.
    Good luck with your project.
  4. #14
    Gold Member
    Join Date
    Feb 2005
    Posts
    474
    Chester County, SE PA
    Kubota L5030 HST
    I am considering doing the same thing to parts of my property. Middle buster looks like it's easy to use. 2 questions come to mind:
    - how deep of a trench can you dig with a middle buster?
    - if the pipe is installed above the frost line will it heave?
  5. #15
    Gold Member
    Join Date
    Sep 2004
    Posts
    455
    I buried a perforated 4" pipe behind my house and put gravel (about 3/4" round) on top of that. It runs like a river when it rains [img]/forums/images/graemlins/smile.gif[/img] It worked for me. There's a slope that comes toward my house and the water was resting there too long so it ended up creeping into a crack in my basement wall. Even with the crack still there it doesn't leak now that I have the drain in.
  6. #16
    Join Date
    Feb 2005
    Posts
    24
    b7500
    UPDATE:
    I made a small trench with my middle buster (~4-6" deep x 12" wide) in a little different layout than my original plan. I was afraid to go too deep on the first pass because of how wet it was (didn't want to get the 'bota stuck). If you look at the attached drawing, I stayed high on the property and tried to catch all the water before it makes it's way into the field. Well, water started flowing almost immediately after I made the shallow trench. I pretty much had created a small stream from the high end of my property then directed it to the low end. I thought that my troubles might be over when I saw all the water flowing, but soon realized that there is water coming up in other areas of my property that are lower in elevation than the trench. Ground water must be flowing under the trench, and up through the ground in the middle of the field. My thought is that I need to go deeper. Does this make sense? My next move is to make another pass with the middle buster and see if I can get down another 6-8". If that doesn't do it, I have access to an excavator but would want to be sure that I was on the right track before I begin a project like that.
    Attached Images Attached Images
  7. #17
    Join Date
    Aug 2002
    Posts
    7,386
    North East CT
    2003 Kubota BX-22
    Give it a few days to drain and then reassess what needs to be done. I have the same problem and am still working on a resolution. Once I have one area dry, it seems that another area is still wet and not draining like I though it would. I just keep attacking it a little at a time until it is all resolved. It is just that every time it finally gets dry enough to work the area, the next day it rains.
  8. #18
    Join Date
    Feb 2005
    Posts
    24
    b7500
    Junkman,
    I should have mentioned that it's been 10 days since I dug the trench.
    The water has been flowing through the trench the entire time, but the field looks the same. It really hasn't made any difference as far as I can see.
  9. #19
    Super Member Highbeam's Avatar
    Join Date
    Feb 2005
    Posts
    5,039
    South Puget Sound, WA
    Kioti CK30HST
    Wow, sounds like lots of water. Worth setting in a deep drain tile with laterals into the field. If you can make a single open ditch work, then you are money ahead but if you must go deep and with a bunch of finger ditches then you really start chopping up your land.
  10. #20
    New Member
    Join Date
    Oct 2012
    Posts
    1
    Buxton, ME
    Kubota 3830
    High Andy,
    I realize some years have passed since you originally worked on this project.
    I am pondering a similar problem in several separated places.
    If you could tell about how it all worked out it would be very helpful
    Thanks in anticipation.
    Tiltphobic
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
