Kubota Shipping Crate >>> My New Workbench
   / Kubota Shipping Crate >>> My New Workbench #1
dholly
Fingerlakes Region, Upstate NY
B7610HST
This post is "For the discussion of all the things you do with your tractor <font color="red"> SHIPPING CRATE</font>!"
<font color="red">*red=my insert</font> /forums/images/graemlins/wink.gif
When I bot my B7610, I noticed it was sitting in a pretty heavy duty metal shipping crate. I figured I could make something out of the crate, so I asked the salesman if I could have it. Not a problem he said, take a few. So I did!
Here's a pic of the crate with the tractor in it...
Used a cut-off wheel in a hand grinder to chop them up and a scotch wheel in a drill to clean them up for primer. Bolted a couple of sections together to fit into the new workshop I'm building...
Put a shelf under and used 3/4" Particle Board for the top and ends, pretty smooth and durable when polyurathaned. Might glue a laminate surface on later. Overall dimensions: big bench = 91"w x 36"d, wing = 80"w x 28"d. Both are 35"h, same as my movable 3' x 3-1/2' center island bench.
I extended a portion of the bench under a window so I didn't always have to look at a wall when working. Had to decide whether to hold the benchtop height below window sill height for asthetics, or higher for comfortable working height. The latter won out. All-in-all, heavy, sturdy and easily disassembled for relocation if desired!
   / Kubota Shipping Crate >>> My New Workbench #5
Nice idea!!!
I've got a pile of those crates out back. I was thinking of making a light duty lawn trailer.
Brian
   / Kubota Shipping Crate >>> My New Workbench #6
I have made a lot of things with those crates. The dealer usually gives them to me just to get rid of the.
My dealer just sells them for scrap pick up, but I knew I could put a couple to good use. Something about that warm fuzzy feeling you get out of recycling something old into a new use for free. Well almost free in this case, I put $7 into the project on account I had to buy the primer. Wood, hardware and the poly were all leftovers. I still have enough steel to make a 3' x 8' hanging wood rack and another to store a convertible hardtop up and out of the way, plus a welding cart.
   / Kubota Shipping Crate >>> My New Workbench #8
</font><font color="blue" class="small">( I put $7 into the project on account I had to buy the primer.)</font>
Oh man... Well, in that case, I guess I can't build a workbench. Way out of my price. Just kidding. Nice setup. I've bookmarked the link and hope you don't mind if I steal your setup.
Brian
Go for it! I needed something quick and was limited by lack of welder, so plenty of room for improvement. I'd be interested in seeing what you come up with. I will be mounting quad receptacle boxes in the furthest left and right corner bracing triangles.
   / Kubota Shipping Crate >>> My New Workbench #10
I need to buy some of that shelving material. Mine seem to have some sort of magnetic pull on all sorts of junk. I can clean it and a couple days later it's all back... /forums/images/graemlins/confused.gif
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
CATERPILLAR 279D SKID STEER (A52707)
CATERPILLAR 279D...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54757)
PALLET OF 2" X 4"...
