Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,822
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Setup: Utility room going to be made into a full bath. It's already plumbed for shower/toilet/sink.
Room is roughly 16' wide by 14' deep with 9' ceilings.
Washer/dryer are on back wall, just offset to the right of being in the middle. Dryer exaust vent from the dryer itself (rear discharge from dryer) goes to the right on the ground maybe 4' and then goes up to the ceiling where it discharges outside. (this is block wall and is all under grade so had to go UP to get it outside)
Ok, wife bought exhaust fan for the bathroom. This thing has an 8", yes EIGHT inch outlet /forums/images/graemlins/shocked.gif
I might see if I can step it down the the same size the dryer uses (I think it's either 4" or 6"?)
None the less, here's my thoughts
Take out the plastic (with wire), dryer vent and replace it with hard ductwork. Put the bath vent in and step it down to the same size used for the dryer.
Bath vent will be near middle of room, perhaps a bit skewed to the back/left side. Anyways, take the pipe from the BATH vent to the back wall, cut it 90 degrees to the right to run parallel along the wall the dryer is on. When the bath vent meets up with the dryer vent coming up from the floor, install a "T" there and allow BOTH items to blow out the same flapper on the outside of the house.
Any thoughts on why I might NOT want to do this??
Any thoughts are appreciated!
/forums/images/graemlins/smile.gif
