rear blade modifications
   / rear blade modifications #1
bher
Lancaster, PA
NH TC 29D
I decided to modify my Befco rear blade to make it better for pushing snow. First I added a 1-inch thick rubber soft edge. Then a 2" by 10" cylinder to add power angle. Finally, I made a plate the bolts to the top of the blade. This extends the height of the blade to 18" The heavy snow that we got last weekend gave me a chance to try everything out. Overall, everything worked great. My productivity is up at least 50%. Here are some pics:
another pic
another
one more
last
   / rear blade modifications #6
thanks for the pic's- been thinking about the power angle idea myself- interesting way you did it. I have some salvaged cylinders from the outdrive of a boat. I just need to come up with a valve.
   / rear blade modifications #7
hey Bher:
Nice work!
Can you provide a source for the hydraulic cylinder?
Thanks,
Runk
   / rear blade modifications #8
Brant,
Nice job, you just gave me the incentive to modify my blade as well. Not only with the rubber cutting edge, but the power angle as well. Only thing is this will lead to adding some more remotes.
Steve
The cylinder came from Surplus Center. I believe it is Chief brand and nothing fancy.
   / rear blade modifications #10
Great post.
Where did you get the rubber at?
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2015 FORD E350 16FT BOX TRUCK (A56129)
2015 FORD E350...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
250HP Mercury Gasoline Outboard Boat Engine (A55758)
250HP Mercury...
Sheets of 12' Tin (A53316)
Sheets of 12' Tin...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
