Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default Seedbed Preparation
    I have 7 acres, and just had the remaining 5 cleared. I used a disc harrow then planted ryegrass. In some areas the ryegrass came up, then turned brown??
    Questions:
    What do I need to do to make the ryegrass grow in the brown areas?
    Should I fertilize?
    Is it a good idea to use a fertilizer spreader for spreading seed? I am considering re-seeding the areas with a fertilizer spreader.
    Thanks,
    Joe
  2. #2
    Join Date
    Jul 2001
    Posts
    1,807
    Sharpsburg, Md
    John Deere 4100 HST
    Default Re: Seedbed Preparation
    What kind of debris was turned under? If you planted immediately after turning under a lot of vegatation and wooded material, it could be draining nitrogen from the soil and killing the young grass.
    Terry
  3. #3
    Join Date
    Sep 2001
    Posts
    501
    South Weber Utah
    Kubota B2710
    Fertilizer on a sick grass is usually the kiss of death. Did you do a soil sample? What was on the land before? Did someone sterilize the soil? Preplant prep of the planting bed is important. E-mail me privately and I'll try and help you. but I am not familar with Florida's climate or growing season.
    Kevin
  4. #4
    Join Date
    Jan 2002
    Posts
    535
    Central Florida
    Kubota L5030HSTC
    I had a root rake remove mostly palmettos and dead pine trees. The soil is sandy, but some of the rygrass is growing well in the sandy areas, while other spots are brown.
    Joe
  5. #5
    Join Date
    Sep 2000
    Posts
    1,373
    Joe,
    Were the dead pine trees in the same areas as the dead grass?
    Al
  6. #6
    Join Date
    Jul 2001
    Posts
    1,807
    Sharpsburg, Md
    John Deere 4100 HST
    JoeR,
    I'm not an expert by any means on grass. Just what I know from my experience. I'd suggest that you email Turfman and see if he has any suggestions. Also, you may wish to contact your county extension office. You may have a problem that is particular to your area.
    Terry
  7. #7
    Join Date
    Jan 2002
    Posts
    535
    Central Florida
    Kubota L5030HSTC
    Yes, the pine trees were in the same area. This whole area burned in 1998 during the Florida wildfires, and almost all of the pine trees died from the fire. The fire was so hot in 1998, that many palmettos didn't make it either...
    Joe
  8. #8
    Join Date
    Jan 2002
    Posts
    535
    Central Florida
    Kubota L5030HSTC
    Here is a picture of the land before it was cleared and with the green and brown ryegrass. I put ryegrass on all the fields. Some areas are green, some brown, and some areas are almost bare.
    Thanks for the help.
    Joe
    Attached Images Attached Images
  9. #9
    Join Date
    Sep 2000
    Posts
    1,373
    Joe, That is a crying shame it didn't turn out like you had hoped. Thats a lot of work. I would get some soil samples taken for the good, bad and the ugly locations and see what turns up there. Also I would question the seed, age, date codes and source. Is anyone else who bought from the same run or source having problems? Hope you can get this turned around.
    Al
  10. #10
    Gold Member
    Join Date
    Apr 2000
    Posts
    424
    Akaroa South Island ,New Zealand (about 1/2 way down south island)
    8350 valmet with 980SL FEL duels had a 150 Hp deutz just sold it 10 NOV 01
    Hi ya Joe
    just looking at ya pic is that water lieing on the top and is it swampy ground ?? to me it lookes like eather to much water or if realy sandy to little .a N lock up will happen on new ground more with spray drilling if ground has been worked the lock up dose not have as bigger affect .
    catch ya
    JD Kid
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
