HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 04-06-2007, 11:59 AM   #11 (permalink)
Default Re: Shop light decision: thanks!
Update.... I have installed all the flourescent lights in the building ... am exceptionally pleased with the results. Wife thinks it's as bright as day.
Net, all the calculations, bulb selections, etc. worked out just right.
__________________
Joy is having the tools you need and needing the tools you have!
Kubota 5030 HSTC, BB, Danhueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall
texasjohn is offline   Reply With Quote
Old 04-07-2007, 11:40 PM   #12 (permalink)
Gold Member
How about some pics John?
__________________
John Deere 5420/4WD/FEL, PwrReverser
8MX Shredder, Belltec TM-48-HTL PHD, WR Long RBG Grapple, 12" Tree Terminator & more...
GaryBDavis is offline   Reply With Quote
Old 04-07-2007, 11:51 PM   #13 (permalink)
OK... will do. Gotta take'em first.
__________________
Old 04-08-2007, 01:41 PM   #14 (permalink)
Here's the lights. Photo taken at night, thus no light thru skylights, using mobile phone camera.
Photos taken from one end of 40X60 shop, so you see 1 bay and a half. Perimenter of shop has commercial metal rack shelving. I try to have everything on wheels so I can rearrange stuff. A friend provided over 100 plastic 5 gal buckets to put things in. Chain hoist hanging from center. One skylight per side on each bay... gives inside light about the same during day.
Ceiling and walls covered with buble radiant barrier... white inside thus reflects light very well. Ceiling lights intentionally not mounted completely symmetrically but more centered over work areas.
3 switches... one for center line of lights, one for the double row on each side.
__________________
Old 04-10-2007, 02:16 PM   #15 (permalink)
Gold Member
Very nice. I bet using that man lift made it an easy job.
I would post pics of my lights, but I'd have to finish installing them first. I just ordered some scaffolding so I can knock that one out. My shop is 22' high in the middle. I hung the first one using a ladder and said this isn't going to work.
__________________
Old 04-11-2007, 09:57 AM   #16 (permalink)
Nice work John.Can you tell us which fixtures and bulbs you used and where you got them.You see,literally,I am at this point in choosing lighting as well.Still trying to decide on which bulbs and fixtures to use.Thanks.
__________________
bones1 is offline   Reply With Quote
Old 04-11-2007, 10:09 AM   #17 (permalink)
bones1, I suspect you saw the photos and quickly wrote your note. By the way, the pictures actually make things look darker than they actually are... the camera I used doesn't do it justice.
The first post in the thread is very explicit about what analysis technique I used ... all the hyperlinks are there.... and exactly which fixtures ultimately I selected and why.... If you have particular additional questions, just PM me and I'll be glad to answer..
__________________
Old 04-11-2007, 10:29 AM   #18 (permalink)
Your'e right John,came in on the tail end of the post.Very good information, thanks.
__________________
Old 04-11-2007, 10:02 PM   #19 (permalink)
cj7
Gold Member
here are some really nice T-5 fixtures for your shop.
2,3,4,and 6 lamp units.
Looks like they sell direct too....
Lightwings LTD - High Performance T5 Highbay lighting fixtures 400 watt HID MH HPS replacement V-wing
cj7 is offline   Reply With Quote
Old 04-12-2007, 10:30 AM   #20 (permalink)
Gold Member
TX JOHN - Thanks for the post. I read the whole thing, but it was a bit confusing for a novice. I'm looking for lights for my pole-barn/shop (36' x 45')(10' ceiling height). I've decided on florescent strip lights, and was thinking 3 banks, using 8' strip lights.
Do you have any tips on what I should be looking for in a shop light fixture or maybe what to avoid?
How about the tubes themselves - what makes a good one?
I was thinking I'd go down to the home store a buy whatever they had on the shelf, but your post makes me think I should do a bit more planning!
woodlot is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
