#1 (permalink) |
We bought 15ac out at the lake with the land bordering Corp of Engineer land on 3 sides. It has a nice build spot on a point over looking the lake. The land had no road access into it. (I will post photos as I go) I bought a SAME tractor as I figured I could build a road myself verses paying some one to do it. I first had to clear about a 30ft wide x 30ft deep section of large evergreens off of the county road. My Husky 455 rancher chain saw sure cut that section out with no problem. The ground slopes up at a sharp angle from the road so after I cut the trees down and cut them up I used my tractor w/fel to push them up out of the way. I dug a trench and dropped a 20ft x 18inch double walled plastic culvert in and covered it dirt and engaged the 4x4 and started digging out the sharp rise in ground. Over the next several hours managed to get it dug down so I could get up over the rise. Once on top I started pushing dirt from on top down the hill to decreased the angle of slope. I used my 7ft woods drag blade to level the ground further on up the property using the dirt I scaped doing this to dump down the slope. While I was there the county guys just happened to drive by with their chipper and they chipped up all the trees for me for nothing and once their dump truck was full dumped it up top in a cople of big piles. That chipper they had was eating big evergreen trunks like pretzel sticks.
My SAME tractor worked hard and ran great.....lots of power. Nothing bad to say about it and the county guys were impressed with all the work I did with it especially on such a steep slope to start till I got it knocked down.....more to follow as i go.
__________________
Ride Fast...Life is Short 2001 Dodge diesel 4x4 dually 1990 Ford F350 Dually 2006 82x18 Landscape trailer 10k 18ft Equip Trailer Bobcat 863 Skid Steer Country Clipper Boss 72in ZTR Country Clipper Boss 60in ZTR CC 54in ZTR 2006 43hp turbo diesel SAME 4x4 tractor w/ Front end loader Pto tillers, box blade, rock rake, 7ft brush cutter, disc, straight blade, grapple, tooth bucket, pallet forks.....soon a power rake Harley Ultra/Night Rod and other stuff. http://kan-ag.com./ |
#2 (permalink) |
Super Member
Dave,
Sure sounds like exiting times for you!!! Take lots and lots of pictures. In just a few years it will be just a memory of what it "used" to look like. All your friends, and even yourself, will have trouble remembering how it was and everything you had to do to cut a road through the woods. Enjoy, Eddie
__________________
My Goals for 2008 1. Fishing and Hunting with my kids. 2. Build my storage Shed. 3. Put my outside access bathroom together. 4. Fence in a quarter acre for Turkeys. 5. Build my gazebo for my front pasture. 6. Finish back pasture and plant it in Bermuda. 7. Start my food plots. 8. Build a comfortable deer stand for two. 9. Build a wood burning fireplace in my home. 10. New flooring in my home. 11. Build a pasture sprayer. 12. Get my old jeep running. |
#4 (permalink) |
Super Member
Obviously that is a "before" photo because there is no dirt on that tractor!
When it comes time to start building the road for yourself, please don't follow the recommendations of our government road builders. Instead go back into history to the Roman empire, those guys built roads that are still in use today after 2000 years! Seems to me my county can build a road that will turn into a pothole obstical course in under 2 years ![]() Dig your road base deep, lay in a geotextile material with rock over it, or lay in multiple layers of rock for drainage and for compression so that you have a good solid base that doesn't move. Keep the center of the roadway crowned a little higher than the edges so water doesn't pool on it. Make sure water near the roadway has clear paths of flow for drainage and doesn't undermine your work, put in culverts as needed and cut swales to direct the water flow.
__________________
![]() Snow Trac, the Swedish Snow Tractor, at Wikipedia Never insult a man with a bag of dog poop in one hand and a tennis racket in the other hand! |
#6 (permalink) |
Lots of rain here today.....very muddy.....did manage to rough blade and chainsaw my way the entire 2500 ft
__________________
#7 (permalink) |
Dave how did you make the ditch for the culvert did you use your box blade with rippers or the front end loader. I need to make a ditch just not sure of a good way to do it ?
#8 (permalink) | |
Quote:
__________________
#9 (permalink) | |
Gold Member
Quote:
#10 (permalink) |
Drive ways need either money or time! From the looks of your photos, no steep hills or heavey forest. Idealy, you would want to remove all the top soil on your road bed and build up the road bed from the future ditch area. This will create an elevated road with good ditches on both sides. This requires a dozer! Then many tri axels (20 ton loads) of #2 base stone. The #2 is a crushed stone about the size of golf balls to lemons. Go with about 6-8". Then drive it for a few months and top with 4-6 " of 5s an 3s and dust. This stone is grape sized and smaller but with lot's of dust. This settles real well and locks it all together. at 2500 ft x 12 ' wide 1.2 ' deep, you will need 1333 yards of stone. This will cost $10,000 to $13,000. in stone.
Or if you want to save money up front, wait untill July when it's real dry and skip the bull dozer work and just get 4to5 inches # 2. Use a yard box to make your drainage. In dry times keep buying stone. Never have stone delivered in wet conditions. The stone they drive over will be half way to China! Save your fine road building for after you build. Concrete trucks will make you cry Looks like a fun project. |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
