HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 01-02-2007, 03:49 PM   #1 (permalink)
Default BIG ROCK PROBLEM????
OK guys and gals, see what kind of method you can come up with to move this rock back away from the water about 10 feet so I can reset it level in the same postion it is now. Problem: ROCK approx. 8 tons. Equipment available: Caterpillar 287 track skid steer (4.5 ton ), Caterpillar 308CCR excavator (8 ton machine) and a JD 3520.
Also the rocks end is at the right hand edge of the pic, behind it is level grassy area so there isn't a problem with getting a machine or to there.
And don't anyone suggest renting a D9 or blowing it up with dynamite.
I took a pic of me on it to give you some scale.
http://i138.photobucket.com/albums/q...c/P1010909.jpg
__________________
"Good judgement comes from experience.Experience comes from bad judgement."
dirtworksequip is offline   Reply With Quote
Old 01-02-2007, 03:52 PM   #2 (permalink)
Default Re: BIG ROCK PROBLEM????
be easier to move the water
randy41 is offline   Reply With Quote
Old 01-02-2007, 04:07 PM   #3 (permalink)
Super Member
Egon's Avatar
Jack it up, put down some timbers, add rollers, attach a 8 shiv. block and tackle, anchor it and start pulling.
Don't stand under it when jacking. Maybe make some cribbing to support it.
Don't need those machines at all.
__________________
Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
Egon is offline   Reply With Quote
Old 01-02-2007, 04:12 PM   #4 (permalink)
Super Member
EddieWalker's Avatar
Do you have allot of logs, some chains and a few friends to run your equipment?
I'd dig up all around it and see if you can lift part of it enough to get a log under it. Then dig a ramp to get it up and out of the ground, or dig a trench to where you need it to go.
Then get the chains around it and pull with which every one of your machines has the most power and traction. If that's not enough, put another machine in front of the first one and pull with both. Keep adding vehicles until you can get it moving.
When it starts to move, put more logs under it and continue until you get it where you want it. If the Egyptions did it with people power, you shouldn't have too much trouble with all your tractors.
Good Luck,
Eddie
__________________
My Goals for 2008
1. Fishing and Hunting with my kids.
2. Build my storage Shed.
3. Put my outside access bathroom together.
4. Fence in a quarter acre for Turkeys.
5. Build my gazebo for my front pasture.
6. Finish back pasture and plant it in Bermuda.
7. Start my food plots.
8. Build a comfortable deer stand for two.
9. Build a wood burning fireplace in my home.
10. New flooring in my home.
11. Build a pasture sprayer.
12. Get my old jeep running.
EddieWalker is online now   Reply With Quote
Old 01-02-2007, 04:14 PM   #5 (permalink)
egon, I rolled it into place on several round treated fence post, but they pretty much splintered to pieces. I had it setting real nice and level. Now its settled into the current postion and I need to rethink the whole thing once I get it rolled back out of the way.
__________________
Old 01-02-2007, 04:20 PM   #6 (permalink)
Eddie, now your thinking. Good idea about digging the trench. I just might be able to get it slightly down hill. Gravity would help tremendously. Do you think a lot of butter would help? hahahaha
__________________
Old 01-02-2007, 04:56 PM   #7 (permalink)
I was shocked at the size of the rock I could move with a 7500Lb L39 Kubota's BH. I kind of picked one end up a bit and swivel and crab it around. I was afraid that rock would slide too far and cream the L39 stabilizers!
I would think the Cat 308 would be able to move this. The other machines haven't a chance. Dig a trench behind the rock and pull it toward the trench. Repeat this several times and I bet you will be able to slide it if it is really only 8 tons.
I'd love a Cat 308!
mike69440 is offline   Reply With Quote
Old 01-02-2007, 05:15 PM   #8 (permalink)
Gold Member
Ken_CT's Avatar
I'll bring my BX23 over and take care of it for you in no time, (just making fun of another thread). But seriously, there is a product called Dexpan, which is an expanding cement. You drill holes, pour it in, wait a day, and it cracks the rock pretty well. From there a rented jack hammer will do the rest. I removed a bunch of large rocks with it a couple of years ago and was impressed with it. It is a bit expensive, but it might do the trick for you. Here's a link.
Dexpan Non-Explosive Demolition Agent
Ken_CT is offline   Reply With Quote
Old 01-02-2007, 06:28 PM   #9 (permalink)
When we loaded the rock on a roll off truck to get it to my place I hooked onto it with a D8 and 20 foot 5/8ths chain. Took the slack out real easy. Let off of the decel pedal and the chain popped like a rubber band. Had to push it onto the rolloff with the D8.
The rock still chained on the truck.
http://i138.photobucket.com/albums/q...R/P7100265.jpg
The rock was facing the other direction on the rolloff so we spun it around with the cat 308ccr while it was still loaded on the truck.
http://i138.photobucket.com/albums/q...R/P7100269.jpg
Thanks to Josh Miller of Miller Trucking for making it happen.
__________________
Old 01-02-2007, 06:34 PM   #10 (permalink)
Ken, I'm sure the dexpan works great, but I hauled this rock in! The rock isn't the problem its that it settled in and now I need to move it so I can reset it in a level position just about where it is now. If I had given it a little more forthought I probably should have poured a concrete footer for it to set on.
Thanks for the help though.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
